What gasket quadrajet to edelbrock dual plane intake
what gasket do i need to but my qudrajet on a dual plane edelbrock intake.. the kind that has both bolt holes to mount either carb
Rust is better than rice.
Re: What gasket quadrajet to edelbrock dual plane intake
You need a spread bore to square bore adapter, not just a gasket.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
i didn't think i would with this intake it's the kind that it should just bolt right on it has both sets of bolt holes and is shaped similarly i swear you didn't need one and that was the whole reason i bought this damn intake
Which dual plane intake did you buy?
idk the name i'll go grab a pic give me a minute
Was it the Performer intake for spreadbore carbs? If so, you need a gasket to match your particular quadrajet carb. Some are different than others.
guess its a performer
so just a basic gasket for my qjet ?
Yes. Make sure its for your model number of qjet. Pull the numbers off of the qjet itself since these trucks are old enough that someone could have swapped out the stock carb years ago.
how about i just take the carb to the parts store that way i know it works before i leave the store. thanks so much btw
That works too. Many base gaskets to choose from. Look here... http://quadrajetparts.com/rochester-...s-c-25_37.html
EDIT: Just remembered, Fast N Loud had an episode where their rebuild kit included the wrong base gasket on an old Buick if I remember right. Wouldn't start. Swapped for the right one and vrooooom!
| Bookmarks |
