Old 04-03-2014, 04:11 PM   #1
msaintg
msaintg's Avatar
parking brake lever
This brake lever came with my '47. I was wondering how many years came with this style brake lever. I haven't been able to find any info on this. My truck was missing the transmission cover, so I assume that is where it came through the floor.
I have been racking my brain trying to figure out how I am going to install it back in my '47 now that it has the S10 drive train (and the parking brake cables coming along the drivers side of the frame). I have the rod that goes with it, but that's all. Any ideas? I'm sure Shannon has a bunch of them.
msaintg is offline   Reply With Quote
Old 04-03-2014, 06:43 PM   #2
OrrieG
OrrieG's Avatar
Re: parking brake lever
according to this table
http://chevy.oldcarmanualproject.com...resto/4885.htm
the hand brakes only came on 3800 and bigger trucks and mounted on the trans mission. The long rod probably connects to a bracket that pulls the two cables going into the backing plates.
OrrieG is offline   Reply With Quote
Old 04-04-2014, 12:47 AM   #3
mr48chev
mr48chev's Avatar
That was one of those distinguishing 1947 AD truck things along with the floor shift three speed http://www.cs.siena.edu/~lederman/tr...ignTrucks.html
In 1948 they went to the column shifter and the pedal over on the left side for the park brake. The one tons and above still had the park brake like that one bolted to the side of their four speeds.
My ongoing truck projects:
Old 04-04-2014, 04:21 AM   #4
msaintg
msaintg's Avatar
thanks guys.
So what your saying is this thing might be valuable on ebay if I can't find a way to mount it, since only the 47 had it?
Old 04-04-2014, 04:57 AM   #5
47 Fasttoys
47 Fasttoys's Avatar
I have the same lever on my '46, and yes it can be adapted to your set-up. I had it mounted to my Lokar bracket for my Turbo 350 and now have it mounted to the current 700R4 bracket to the right side of the shifter. For mine, I used a third cable conecting the 2 E-brake cables and a half moon adjustable cable pull mounted to the end of the rod to pull the cable. I not sure if I have any pictures in China but I can take some in a couple of weeks if you have not figured it out by then. Just let me know.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 04-04-2014, 10:48 AM   #6
mr48chev
mr48chev's Avatar
Depending on what you use for a shifter you should be able to fab a bracket to mount it on. It might depend on the trans too though. I think If you look at photos of Lokar Or American shifters you can get some ideas.
Here is a link to the American shifter floor/trans mounted E brake handle. This is for ideas to mount yours only and not an endorsement for their products. You just have to figure out how to mount it solidly so it works right. http://www.americanshifter.com/catal...Brake-Kit-~-11
Old 04-04-2014, 03:09 PM   #7
msaintg
msaintg's Avatar
thanks guys,
I have the 4L60E, column shift transmission (so this lever would be the only thing sticking up in the middle of the floor). don't know if that would look funny. I think I can figure out the mount. What I am puzzled on is routing it from the center over to the drivers side and then connecting it up to the S10 parking brake lines (which come half way up the cab)
