Old 04-03-2014, 04:22 PM   #1
62k10&84k20burb
62k10&84k20burb's Avatar
1968 c30 4wd conversion
I've been thinking about a 4wd swap in my 68...any info/ideas/specs? Would a k20 chassis work?
62 k10 235/sm420
68 3500 250/sm465/eaton ho72/5.14s
84 burb k20 350/700r4/14bsf/10b 3.73s
62k10&84k20burb is offline   Reply With Quote
Old 05-14-2014, 10:06 AM   #2
rs74
rs74's Avatar
Re: 1968 c30 4wd conversion
I have searched 4wd conversion but didn't come up with anything other than some wanting to do the same. Never came across a thread that showed the actual build of one and how to convert over. Would be interesting to read and see the pics of one that has done a C30 to K30 build. Maybe I am not using the right key words.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 05-14-2014, 01:04 PM   #3
airdale94
airdale94's Avatar
I "think" what you would want is a 73-87 K30 frontend swap.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 05-14-2014, 01:09 PM   #4
OldCreek
OldCreek's Avatar
I did a 68 C30 frame to K30 for my crew cab.
I used a lot of stock K20 parts, i.e. leaf hangers and some Diy4x and ORD parts to hang the leafs/axles etc.
The rear portion of a C30 frame (at least the 156" wheelbase) is a lot taller and kicks up higher than the 10/20 frames… and, therefore, you may need a body lift on the cab to match up with a bed placed on the rear frame. (Unless you go with a flat bed, for example.)
Sadly, I lost my bare frame photos so I can't show you what I mean.
I sold the crew cab a few months back, also.
Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-14-2014, 05:53 PM   #5
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Friend of mine did a C-10 2WD to 4WD suspension & components swap on a '71.
Sorry no photos. Turned out nice, but:
He said "Never - NEVER - EVER again !!!!!!"
Felt like it would have been way-easier to do a body-swap onto a 4 WD frame
68shortstep is offline   Reply With Quote
