Old 04-03-2014, 07:03 PM   #1
70BigBlock
How do I fix this?!!!!
I'm putting the truck back together, as i put the passenger front fender to the cab. I noticed that this bolt was lose and didn't want to tighten up. I guess what helps it tighten up from the inside got lose . Can somebody please tell me how to fix this .
70BigBlock is offline   Reply With Quote
Old 04-03-2014, 07:07 PM   #2
Molberg
Molberg's Avatar
Re: How do I fix this?!!!!
Pics would help
Edit.. They just loaded for me
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 04-03-2014, 07:08 PM   #3
Molberg
Molberg's Avatar
Like the bolt up under the dash? It's spot weld broke loose? Just spins?
-Project Nitemare-
Old 04-03-2014, 07:12 PM   #4
70BigBlock
Yea, the one that's spot welded , it broke lose so everytime I try to tighten the bolt, it just spins inside.
Old 04-03-2014, 07:12 PM   #5
Molberg
Molberg's Avatar
It should be a 3/8" bolt. (9/16 head) if it just pulled out... Maybe a smaller size was stuck in?
-Project Nitemare-
Old 04-03-2014, 07:13 PM   #6
Molberg
Molberg's Avatar
Looks like the inner one. May be able to reach it up in behind glove box.
-Project Nitemare-
Old 04-03-2014, 07:17 PM   #7
Molberg
Molberg's Avatar
Just tried on my truck. Can't reach it from under dash or under cowl.
-Project Nitemare-
Old 04-03-2014, 07:17 PM   #8
70BigBlock
I have the correct bolt it just the the thing that helps it tighten broke loose . I tried to get to it but i end up hitting a steel wall from every angle
Old 04-03-2014, 07:22 PM   #9
Molberg
Molberg's Avatar
That sucks. Shy of drilling a small hole right beside the bolt..through the whole works. Stick a pin through it to keep it from spinning maybe. Tough one
-Project Nitemare-
Old 04-03-2014, 07:29 PM   #10
70BigBlock
Thanks , Yea I know, that's going to slow down my build. Anybidy else have this problem that can tell me how they fixed it . ??
Old 04-03-2014, 07:33 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
What I do is to drill a whole through the skin into the bolt behind the panel. Then plug weld the bolt to the cowl panel. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-03-2014, 07:53 PM   #12
Molberg
Molberg's Avatar
Yep... I agree with you there. Wasn't sure if he planned on pulling the fender, or just tryin to get it tight again
-Project Nitemare-
Old 04-03-2014, 07:56 PM   #13
70BigBlock
I would like to be able to take it off again so I can open up and close the gaps on the doors and also once the truck gets painted. .
So I drill a hole from the inside of the cab and weld the lose part back to where it was ?
Old 04-03-2014, 10:31 PM   #14
Tinkermc
Did you try an impact wrench to tighten it?
Tinkermc is offline   Reply With Quote
Old 04-03-2014, 10:39 PM   #15
70BigBlock
You mean for the impact wrench to give it quick spin so it can tighten up?
I'll try it, is the only way to fix it going to be to cut from inside the cab and spot weld it back so I won't have this problem everytime I take the fenders off?
Old 04-04-2014, 02:31 AM   #16
ho70
ho70's Avatar
Long shot......see if you can get a nut insert the same size as the bolt and install the nut from the outside with the nut insert tool. Nut inserts are used to install side view mirrors. If you can't get one big enough, use the biggest one available and use a bolt with a large washer
Good luck!
ho70 is offline   Reply With Quote
Old 04-04-2014, 07:31 AM   #17
67c10rustbuket
67c10rustbuket's Avatar
cut the bolt head off and remove the fender. grab the bolt with vise grips so it does not fall into the pillar (if possible) drill two small holes then pull the bolt so the nut plate is flush and plug weld it back to the pillar. remove bolt, if needed weld a nut onto the cut bolt to use a ratchet. Run a thread repair tap into the nut plate. reinstall fender.
Look at this thread, should give you an idea of what is behind the pillar.
http://67-72chevytrucks.com/vboard/s...d.php?t=621080
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-04-2014, 07:32 AM   #18
Keith Seymore
Keith Seymore's Avatar
x3.
Came here to say this. Shouldn't take much to hold it in place and keep it from spinning while you torque it up.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-04-2014, 11:38 AM   #19
ho70
ho70's Avatar
Originally Posted by Keith Seymore View Post
x3.
K
Am I missing something, has the interior nut weld broken and the nut has fallen so the bolt threads into nothing or does it still thread into the nut but won't tighten?
Old 04-04-2014, 11:56 AM   #20
70BigBlock
The thread is still on the bolt, but the bolt won't tighten up because the thread is loose inside the cab.
