07-27-2003, 06:12 PM | #1 |
Young truck fanatic
I really want some Hood Hinges!!
I am posting this again because i just cant stand my hood sticking up on one side anymore and i need some Hood hinges that are in good condition.
Thanx |
07-27-2003, 06:32 PM | #2 |
67-72 truck surgeon
Good used hood hinges will be very hard, if not impossible to find. I suggest that you look into buying new.
1969 Chevy C10 1993 Toyota Camry LE 1999 Ford F250 Super Duty 4x4 diesel 2008 Dodge Charger Super Bee 1953 International R182 |
07-27-2003, 07:08 PM | #3 | |
Bloo
im going to get pics for you after while on the ones i offered, but if your hood is sticking up it can just be the adjustment of the hinges... have you tried adjusting them to get em down?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-27-2003, 09:39 PM | #4 |
Scroll about halfway down.
http://www.gmpartsdirect.com/restora...tocategory.cfm |
07-27-2003, 09:42 PM | #5 | |
Bloo
heres the pic i posted on the other post just in case you see this one first, take your pick out of them if you still want a set... the 3 on the left are for the drivers side and the 2 on the right are passanger.. the dark one i know is good
07-27-2003, 10:03 PM | #6 |
i got some good ones wont be useing them but i know there good from a 67 i'll post a pic
07-28-2003, 10:41 AM | #7 |
Young truck fanatic
Chevy 68 what do they look like?
07-28-2003, 10:57 AM | #8 |
did you adjust the hinge downward on that side? just open the hood and loosen up the two bolts that hold the hinge to the fender. then lift up on the front of the hood and the hinge will rotate downward. then just tighten up the bolts
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
07-28-2003, 11:16 AM | #9 |
Young truck fanatic
Yes I tried adjusting but the hinge is broken. There is a flat piece at the bottom of the two arms of the hinge that has two big rivets through it that is supposed to hold them in place and it broke therefore when the hood is closed it sticks up on the passenger side about 1/4 of an inch.
07-28-2003, 12:24 PM | #10 |
Navel Inspector
Mine does the same on the drivers side. I will be trying all of the advice as well and if that doesn't work buying new. :p
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
07-29-2003, 11:36 PM | #11 |
sweet n rare 67 hold up i cant shrink the pick maybe i can send it to your email
