Old 04-03-2014, 10:45 PM   #1
c10 custom
spark issue mystery on 84 chev
Hi everybody having an issue with a 1984 chev truck it has no spark when in the cranking position but when the ignition switch is released it has spark i was thinking maybe the starter solenoid wire but not sure any help would be great thank you
c10 custom is offline   Reply With Quote
Old 04-04-2014, 12:12 AM   #2
ray_mcavoy
Re: spark issue mystery on 84 chev
That's most likely a problem with the ignition switch. The "IGN 1" terminal (pink wire) should have power in both the "RUN" and "START" positions. It sounds like your switch is no longer powering that terminal in the "START" position.
The starter solenoid wire connects (through the neutral safety switch) to the "SOL" terminal. That terminal only has power in the "START" position and is only used to crank the engine ... it doesn't feed power to the ignition system.
ray_mcavoy is offline   Reply With Quote
