04-04-2014, 07:54 AM | #1 |
Porter built motor mounts
I'm looking for a set of motor mounts for the extreme drop member that fit a small block chevy. Thanks, Jeff
04-04-2014, 08:06 AM | #2 |
67-72 parts collector,…
Re: Porter built motor mounts
I would call Porterbuilt.
There are many versions of the the Extreme Dropmmember. You need to get the correct set for YOUR Dropmember.
04-05-2014, 04:44 AM | #3 |
I will do that lolife. I tried a couple of times to get ahold of them with no response. I've had the front and rear dropmember installed for a couple of years then had to put this project aside, now I'm going to start working on it again. I was going to go with an LS but came across a small block 350, that's why I was looking for the other motor mounts and didn't realize there were different versions of the motor mounts. Thanks for letting me know Keith. Jeff
