Old 04-04-2014, 09:45 AM   #1
CHASE71
CHASE71's Avatar
Pro street rally wheel specs?
Got a 71 swb w/ a ECE 4/6 drop and I just finished mini tubbing it. I have a pair of 29x15.5r15 hoosier pro street radials already and I am about to pull trigger on a set of custom rallys from Stockton Wheels.
15X12 8" backspacing -rear
15X8 4.5" backspacing -front w/ probably some 235/70r15 BFG
I think this will work. Please let me know what you think.
CHASE71 is offline   Reply With Quote
Old 04-04-2014, 09:55 AM   #2
CHASE71
CHASE71's Avatar
Re: Pro street rally wheel specs?
Some pics
Old 04-04-2014, 09:59 AM   #3
CHASE71
CHASE71's Avatar
Another pic
Old 04-04-2014, 10:00 AM   #4
CHASE71
CHASE71's Avatar
One more
Old 04-04-2014, 12:15 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
Stock width rear axle?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-04-2014, 12:16 PM   #6
geezer#99
geezer#99's Avatar
Before you pull the trigger measure and measure again.
Those big meats need a 11" to 13" wide wheel.
Here's a link to best figure it out.
http://www.carcraft.com/techarticles...t/viewall.html
geezer#99 is online now   Reply With Quote
Old 04-04-2014, 12:19 PM   #7
CHASE71
CHASE71's Avatar
Yes sir stock axle
yeah 12" is what they recomend for that size tire.
Old 04-04-2014, 12:23 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
4.5" backspace on your front 15" wheels is going to cause clearance issues with your lower a-arms (rubbing).
You'd be better off using a 15x7 with a 4" backspace.
(3.5" bs would be even better,... but I don't know how far you would want them to stick out)
Keith
Convert to disc brakes.
Old 04-04-2014, 12:27 PM   #9
CHASE71
CHASE71's Avatar
I am curently running
255/60r167 on 17"x8" 4.5"bs -front
275/60r17 on 17"x9" 5"bs- rear
no problems at all. I am a little worried about 15's on front with my drop. Anyone having any clearance issues with inner wheel rubbing? Also plan on notching it and droping it another inch or 2 all the way around.
Old 04-04-2014, 12:33 PM   #10
CHASE71
CHASE71's Avatar
With 15x7 and 3.5bs it will put the outer lip of the wheel at the same place as my current set up, right?
Old 04-06-2014, 09:29 PM   #11
CHASE71
CHASE71's Avatar
Ttt
Old 04-06-2014, 11:06 PM   #12
Hart_Rod
Hart_Rod's Avatar
I've had 15x12s and I am currently running a 20x12 on the back of my 68 with a factory rear axle. Both sets of wheels had with a 7" backspacing.
Hart_Rod is offline   Reply With Quote
