04-04-2014, 07:16 PM | #1 |
LED Tail lights $30 in 30 Minutes
I decided I wanted LED Tail lights on my 61 Suburban. After looking everywhere I could not find anything. I came up with the following plan to make my own. I started with Semi trailer LED sealed lights.
I started by cutting the red lens off of the LED lights. |
04-04-2014, 07:22 PM | #2 |
Re: LED Tail lights $30 in 30 Minutes
Next I determined they were to thick to fit behind the stock lens. I did not want in any way to modify or destroy the stock aluminum bulb/light housing. So I used a handsaw to cut the plastic surrounding the plug on the back off. I then used a die grinder to grind the brass electrical terminals flush with the back plastic. Then I soldered wires on to the brass terminals.
04-04-2014, 07:26 PM | #3 |
After that I used simple electrical tape to insulate the electrical connections from the light housing. The light fits snug in the housing, but I used double sided foam tape to keep it from rattling around behind the stock lens.
04-04-2014, 07:36 PM | #4 |
Final Product. I only spent about $30 on the two LED lights and after hours of planning in my head, it only took about 30 minutes to actually make them fit.
04-04-2014, 10:12 PM | #5 |
Great idea, looks slick. Any issues with blinkers/brake lights?
1963 C10 short-wide Turbocharged 454, T56, 4.11 posi http://67-72chevytrucks.com/vboard/s...d.php?t=605408 1963 C10 suburban Unknown, unknown, 3.73 open http://67-72chevytrucks.com/vboard/s...d.php?t=622037 |
04-04-2014, 10:22 PM | #6 |
This is so o great of you to share this idea. Big thumbs up! Thanks.
MusicMan70 1961 GMC Suburban |
04-04-2014, 10:45 PM | #7 |
very nice thank you for the Post.
Trueman |
04-04-2014, 11:24 PM | #8 |
Hollister, CA.
Great job !
Ive thought about doing this ever since LEDS were introduced to the commercial industry in the mid 90's .... Thanks for sharing with the group
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
04-04-2014, 11:36 PM | #9 |
Chevy addict
I use 57 Chevy passenger car leds for this type of thing, they are real flat.
Installed them in my buddy's 57 Tbird, they work great. A little more expensive but more leds. |
04-05-2014, 11:09 AM | #10 |
came out great, nice job
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
04-05-2014, 11:26 AM | #11 |
Looks great! ESP since you kept the stock tail lights. Thanks for the info
04-05-2014, 09:16 PM | #12 |
very cool ideal looks good thanks for the post
01-03-2015, 11:53 AM | #13 |
great post i had read this when you had first posted and i had bookmarked it but my laptop crashed and i lost it ...so did you need to modify the flashers
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
01-03-2015, 05:14 PM | #14 |
great idea. I'm going to modify mine thanks.
01-06-2015, 05:35 PM | #15 |
I did the same thing to mine except I spray painted the housing chrome and added a few pieces of reflector tape just because. I used an led panel that was suppose to be for a harley tail light. I did however put a screw into the housing. I had a spare set of housings. Here's how mine looked as tail lights
01-07-2015, 11:03 AM | #16 |
free candy inside did you have to add a resistor to slow down the flasher
01-07-2015, 11:13 AM | #17 |
great idea
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-07-2015, 11:40 AM | #18 |
Nope. It worked like it was suppose to. However, I am running a wiring harness from a 95 Chevy. My drivetrain is a TBI 350 so I used the complete harness including the headlight switch, turn signal flasher, etc. I just wired in the turn signal wires from the 95 harness into the turn signal switch from the 63. I doubt that has any effect though.
01-08-2015, 10:43 AM | #19 |
ok thanks
