Old 04-04-2014, 10:41 PM   #1
trevarthan
Grinds in 1st, but only after leaving it in neutral for a bit
My 1971 C10 L6 three on the tree grinds in first, but only after leaving it in neutral for a bit. For example, during normal driving, 2nd to 1st is fine. But if I sit at a stop light for a while in neutral with the clutch relaxed, I have to count slowly to five or else it will grind going into 1st.
What's going on?
Clutch dragging?
Thanks!
trevarthan is offline   Reply With Quote
Old 04-04-2014, 10:57 PM   #2
88Ironduke
Re: Grinds in 1st, but only after leaving it in neutral for a bit
The clutch may need a slight adjustment. But I believe the Saginaw three speeds did not have a synchronized first gear. Please correct if I am wrong here. I know my 3OTT will grind if not allowed to kind of "spool down" the rotating bits and pieces. I also swapped out my shifter bushings and that helped clean up the feel of the column. There is an awesome post on properly rigging the shift assemblies.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 04-05-2014, 01:05 PM   #3
trevarthan
Downshifting from 2nd to 1st is never a problem. I don't think that would be the case if 1st wasn't synchronized.
Old 04-05-2014, 01:17 PM   #4
geezer#99
geezer#99's Avatar
Just blip the throttle before you try to slip it into first. That'll speed up the input shaft, push the clutch in and slip it into gear.
geezer#99 is online now   Reply With Quote
Old 04-05-2014, 01:54 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... Also known as "double clutching" or "Heel-toe" shifting. ^^^
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-05-2014, 02:21 PM   #6
imjeff
imjeff's Avatar
The syncros get worn over time as does the linkage. Just wait a bit longer after you push the clutch in so the transmission can stop spinning. Blipping the throttle won't help going from neutral to first.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-05-2014, 02:48 PM   #7
jabborabbo
jabborabbo's Avatar
If I'm sitting at a light or wherever in neutral I just shift into second then shift into first before moving on...no grind that way.
jabborabbo is offline   Reply With Quote
Old 04-05-2014, 04:29 PM   #8
geezer#99
geezer#99's Avatar
It sure will!
Have you ever driven a totally non-synchro tranny. AKA a crashbox. You need to match the engine speed to the gear speed to shift.
Afterall the clutch is only needed to get moving no matter what manual tranny you use. After that you only need the right rpm to shift up and down.
Old 04-05-2014, 04:41 PM   #9
imjeff
imjeff's Avatar
Originally Posted by geezer#99 View Post
It sure will!
That works for DOWNSHIFTING. I have driven many, many non-synchro transmissions. I rarely use a clutch when shifting and am fully aware of how to match engine and transmissions speed. When a trans output shaft is spinning at 0 rpm and you "blip" the throttle from 800 to 2000 rpm, how does that match their speed? When downshifting the method you describe works. The poster is talking about starting from a dead stop in neutral. The grinding is caused by the transmission cluster spinning while a gear is being engaged. The clutch disconnects the trans from the engine so the cluster stops and a gear can be selected while stopped.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 04-05-2014, 10:12 PM   #10
That's what I do
Old 04-05-2014, 11:02 PM   #11
slikside
slikside's Avatar
Ditto. Works on just about any manual tranny I've ever driven. Imports too.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 04-05-2014, 11:17 PM   #12
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
X4
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-06-2014, 09:45 AM   #13
trevarthan
I'm going to try this and a few other things today and see what happens. I think he thinks spinning the transmission up in neutral will spin the gears up. I'm not sure if it will or not. I'll report.
Old 04-06-2014, 10:37 AM   #14
19673ontree
CAN'T FIX NOTHIN
The idea of going from neutral to first is to STOP the gears not spin them thats what putting it up in second will do it will stop the gears spinning so you can get the first gears to mesh ,, I tried this on my 67 yesterday after reading you post and it is much easier if you go fr second ,,,,
underdash AC
Old 04-06-2014, 10:40 AM   #15
trevarthan
Yeah, that makes sense. Thanks. Second to first it is then. Hopefully my shifter doesn't get stuck. :p
Old 04-06-2014, 11:01 AM   #16
1971 cheburban
Wow, from a 3OTT question to driving an eaton fuller 13 all in one post
1971 cheburban is offline   Reply With Quote
Old 04-06-2014, 11:38 AM   #17
trevarthan
No clue what you're talking about. The three on the tree shifters have bushings that wear over time. When I bought mine, it was getting stuck between 1st and 2nd quite a bit. I took it to a mechanic near where I bought it and he lubricated everything. So far I haven't had a problem since, but I feel like I'm waiting for someone to smack me over the head with a 2x4. I keep a wrench in the glove box just in case.
It's an unrelated issue, except that if I have to hit 2nd first, then hit 1st, from a stop light under pressure of the cars behind me, I'm more likely to bind it again. Fingers crossed.
Old 04-06-2014, 12:47 PM   #18
jabborabbo
jabborabbo's Avatar
It was binding as you went from 2nd to 1st?
Old 04-06-2014, 02:08 PM   #19
trevarthan
Yes. Actually, I just taught my partner to drive the truck, and she found out real quick that it still sticks if you shift too quickly. Then, just to add insult to injury, I got it stuck myself coming back from Autozone just now. I'd love to figure out how to fix that problem for good. It's pretty damn annoying.
Old 04-06-2014, 10:37 PM   #20
luvbowties
luvbowties's Avatar
Smile Re: Grinds in 1st, but only after leaving it in neutral for a bit
To avoid the hangup you are describing, when going from 1st to 2nd, move shift-lever a tad further "towards reverse" before letting it down to move on into 2nd. IE, accentuate the "H" pattern during 1-2 shift. After all, an "H" pattern is what it was designed for; but over time we tried to 'shorten' it into a more triangular shift--causing excessive wear on a wrong part:the gear-selector lug.
Also, to cure original problem you mentioned, you can shift into 2nd OR 3rd before going to 1st--either eliminates the grinding when finally going into 1st gear. Sometimes(and JUST sometimes), adjusting the clutch will help.
Sam
luvbowties is offline   Reply With Quote
