04-05-2014, 12:12 AM | #1 |
axle question ?
iam wanting to change my rear end on my 70 to a 5 bolt lug pattern ,I have a 5 bolt lug rear end from a 1971 donor truck,can I pull axles from the 5 lug rear and slide into the 6 lug rear end ,if so will I have to change backing plates ,or anything else
04-05-2014, 10:39 AM | #2 |
Re: axle question ?
back when I found out the funny squeeking noise in my truck was absolutely no gear oil I installed a rear out of a 75 in my 70....the 6 lug axles swapped right into it,brakes and backing plates the same...this was on a leaf spring truck....I understand the earlier housings were narrower so the axles were shorter but I think 70 and up you're ok...just measure the housing and if its the same you're good
1970 short step c10 leaf spring 454 |
04-05-2014, 11:33 AM | #3 |
Re: axle question ?
The rear ends are narrower on the earlier models and the axles may be too long. I just did a 5-lug conversion on my '67, and I found it easier and cheaper to just replace the entire rear end and front spindles. I got both from a '72 for 300 bones including the complete steering assembly and power steering box. with lines. I installed the power steering first, then tore apart the '72 xmember. Took one day by myself, including all new Moog ball joints, tie rod ends, and control arm bushings. I used the '67 control arms, used the correct ball joints and tie rods for the '72. Added new calipers ($20 ea.)
Turned the discs and drums. New shoes and wheel cylinders in the back. New pads in the front. $200 bucks gets you a vacuum booster, master cylinder, and prop valve. A few new brake lines installed on the rear of the front xmember to the discs. Threw on a set of '80's 8" rallys with 275/60/15's, and rollin!
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
04-05-2014, 11:35 AM | #4 |
Re: axle question ?
pics
04-05-2014, 01:18 PM | #5 |
Re: axle question ?
Five bolt axles should slide right into a '70 housing. '69 and older housings are narrower (about an inch I think)
04-05-2014, 01:23 PM | #6 | |
Re: axle question ?
04-05-2014, 06:34 PM | #7 |
Re: axle question ?
ALSO? can I swap out spindles to 5 lug or do I have to use complete front suspension ?? thanks for the info,it great to get the answers before tearing into so I know what all I will need ..
04-05-2014, 07:24 PM | #8 |
Re: axle question ?
1970 is the only year you can just change the rear axles in. Did it to mine and bought the 5 lug drums it was super easy.
On the front I used 2.5 drop spindles made for 1973 to 87 disc brakes.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
04-05-2014, 09:50 PM | #9 |
Re: axle question ?
In 1970 5 lug disc stuff was an option... many will argue...I've solds parts for the 70 disc brake pickups.
IF, IF the 70 6 lug axles are the same length as the 71 and up (which includes 73-82, BTW), that would be awesome!!! I had not heard about the 6 lug 70 rear ends being wider than the 69 and earlier... The spindles, is all you need. BUT the upper ball joint is different. Can't remember about steering linkage, will check, though... I have a 67 and 68, BOTH will have 5 lugs, and disc brakes, when I get them back on the road, life's too short for front drum brakes!!! |
04-05-2014, 10:32 PM | #10 |
Re: axle question ?
what upper ball joint do I use ? and thanks
04-06-2014, 02:18 PM | #11 |
Re: axle question ?
04-06-2014, 02:25 PM | #12 |
Roadtrip!
Re: axle question ?
Part way through 70 was the change to a wider rear end. Best thing is to measure and see if it is the same as your donor.
The front discs didn't come out until 71, so you will want to get your parts for that i would think.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
