Old 04-05-2014, 02:00 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Best place to buy a tilt column?
Wanting to buy a restored or good quality new tilt column for a 1970 c10? Any thought or who do I contact?
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 04-05-2014, 02:03 PM   #2
Lattimer
Lattimer's Avatar
Re: Best place to buy a tilt column?
If you are ok with aftermarket either ididit or Flaming River.
Whatever you decide---DO NOT buy one from CPP.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-05-2014, 02:06 PM   #3
bigmac73
bigmac73's Avatar
contact Kevsclassics on here , he is the man to see about getting a refurbished GM column
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 04-05-2014, 02:33 PM   #4
Hart_Rod
Hart_Rod's Avatar
Summit and Jegs has decent prices on the aftermarket columuns (Ididit/FlamingRiver). DON'T buy one of their Summit brand columns.....
Hart_Rod is offline   Reply With Quote
Old 04-05-2014, 04:23 PM   #5
Duvall
Kevsclassics the only place!!
Duvall is offline   Reply With Quote
Old 04-05-2014, 09:02 PM   #6
71 super
71 super's Avatar
Kevs is the best
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 04-06-2014, 02:16 PM   #7
BADPURPLE70CHEVY
406 Powered
Thanks fellas I will check with him.
70 GMC
68 c10
2002 silverado
72 4x4
Old 04-06-2014, 02:56 PM   #8
nicks diner
nicks diner's Avatar
I am curious to why. My mechanic installed it and it looks and works perfect. Have you or others have had bad experience with this column?
nicks diner is offline   Reply With Quote
Old 04-06-2014, 04:18 PM   #9
Tillik
Tillik's Avatar
I believe there is a post about unsafe aftermarket steering columns. They use plastic parts in places that shouldn't be. If that plastic knuckle breaks while your driving you will lose all steering. Someone else could probably post the link. Original GM, Ididit and Flaming river are not on the unsafe list.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
