Old 04-05-2014, 09:02 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Holley carbs on our trucks
I seem to be finding alot of holley's on our years, what are they worth? This latest one I hauled hasn't run for 5 years, it has a 750 double pumper. Thanks for any help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 04-06-2014, 01:04 AM   #2
airdale94
airdale94's Avatar
Re: Holley carbs on our trucks
I would think a good 750 double pumper would be worth at least a $100. The 600 single feeds should be worth $50. Newer ones should be considerably more.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-06-2014, 02:20 AM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
Agreed. DP's will almost always sell, but I've had 600 vac's that I literally couldn't give away. I've chunked a lot of them.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-06-2014, 03:57 PM   #4
DreamRyder1963
DreamRyder1963's Avatar
Next time you chuck one, chunk it my way I have had really good luck using holleys on street trucks which is probably why you see a lot of trucks with them.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 04-06-2014, 04:09 PM   #5
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Owned holleys all my life hate double pumpers the 1967 67 69 camaros with 302s ran a 780 dual line single pump and it works PETFECT on a small block ive had many of them , I redid my 67 327 and I ordered a dual line single pump 750 holley from summit bolted it on two years ago and have not touched it !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-06-2014, 05:17 PM   #6
67_C-30
67_C-30's Avatar
See, I'm exactly the opposite. The Holley DP's with 4 corner idle circuits are the only Holley's I've ever really liked. You just give up too much power with a vacuum secondary Holley. I've seen dyno tests where DP's made 20 or more HP and run 2 or 3 tenths slower in the 1/4 than the same CFM vacuum secondary Holley. A DP will get similiar fuel mileage, ya know, as long as you keep your foot out of it! The only real "problem" with a DP is that people put them on weak engines with high gears and automatic transmissions and mash them to the floor and they bog. You can put a 600 DP on mild engine and make power than 750 vac AND get better mileage, if driven normally.
For this reason, I use tuned Q-jets on mild street driven vehicles and DP's on strong street/strip engines or race engines. There is just no place that I've seen that a vacuum secondary Holley gives me any advantage. The thing that makes them popular is that you can pull them straight out of the box and they run OK for most any engine with minimum tuning, and that's Ok with the majority of people.
My trucks
