Old 04-05-2014, 10:07 PM   #1
Sethmark
Original wheel/ late model column
Need some technical expertise. I have a mid 60s pickup wheel that I want to put on an 85 truck column. I know the splines match. Anyone know what it takes to get the horn to work?
Thx.
Sethmark is offline   Reply With Quote
Old 04-07-2014, 10:29 PM   #2
Sethmark
Re: Original wheel/ late model column
Test for echo..... No one has ever swapped to a modern column and kept the factory steerign wheel?
Old 04-08-2014, 01:14 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
One of the adapter kits might do the trick. Here's the Ididit example, I know there are others:
http://www.summitracing.com/parts/id...0040/overview/
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-08-2014, 09:29 AM   #4
earl84
I'm hoping you get some answers here, because I want to do the same thing. Just swapped in a tilt column from a motor home, and want the old steering wheel on there instead of the newer one. I plan to eventually rework it and make it a shallower dish and smaller diameter, but that will have to wait for a while.
earl84 is offline   Reply With Quote
Old 04-08-2014, 10:05 AM   #5
luvbowties
luvbowties's Avatar
Smile Re: Original wheel/ late model column
I made that same swap--from a 1974 m/h to a 1966 C10--and IIRC, the original wheel bolted right on and the horn worked w/o any mods* at all. BTW: that column had NO key, which made it an ideal swap. *I did tie the wires properly between the 2 columns. ymmv
Sam
luvbowties is offline   Reply With Quote
Old 04-08-2014, 02:53 PM   #6
kieth
kieth's Avatar
Sometimes it takes a little while to get to the people who know the answer to your question. This is not Wikipedia ha ha......
kieth is offline   Reply With Quote
Old 04-08-2014, 05:43 PM   #7
luvbowties
luvbowties's Avatar
Wink Re: Original wheel/ late model column
Hey, kieth. You shouldn't deliver false hopes(re: "Wikipedia"): you KNOW that you and I know everything--and we'd already revealed all we knew!!!
Sam
Old 04-08-2014, 06:07 PM   #8
Sethmark
So.... The splines are right but the horn button is on the wrong side of the wheel. Grrrr..... Highly disappointing. Anyone want to buy a really good condition 60 wheel?
