Old 04-05-2014, 10:33 PM   #1
Jgowin
Jgowin's Avatar
1999 Z71 steering issue
My 99 Z71 that a steering issue, the truck turns nice and easy to the right but turning left it feels like manual steering. I suspected the idler assemble so I replaced the idler, idler bracket, and pitman. After reassembly it still feels pretty much the same. I did feel slack in the idler before replacing and suspected it was binding. What would be best to check next? The tie rods and ball joints appear to be ok but maybe I'm overlooking something.
Jgowin is offline   Reply With Quote
Old 04-06-2014, 07:16 AM   #2
Boog
laying low
Boog's Avatar
Re: 1999 Z71 steering issue
I would separate the pitman arm from the steering sector. With the wheels off the ground turn them from side to side and feel for resistance. If none found then get inside and turn the steering wheel from lock to lock and feel for resistance. That should narrow it down some.
Boog
Old 04-12-2014, 09:34 PM   #3
Jgowin
Jgowin's Avatar
I'm leaning toward replacing the steering box, the steering is free and easy with the wheels off the ground, but I'm going to check the power steering hoses to make sure one of them are not clogged or failed internally. If the hoses check out I'm most likely replacing the gear box.
Old 04-16-2014, 10:05 AM   #4
Jgowin
Jgowin's Avatar
Well the issue turned out to be the steering box, installed a rebuilt unit from Advance, refilled the power steering fluid, and purged the air from the system. Turns nice and easy now, the original gear box had only a little bit of play and turned easy with no weight on the wheels. The truck has a 150k on it which fairly low for a 15 year old truck.
