Old 04-06-2014, 11:12 AM   #1
Bullett
Interior door panel adhesive
O.k., have another question. What do you guys use for an adhesive on interior door panel? I can see the previous owner used some type of adhesive but it is starting to pull away from the door. I would like to re-glue but not sure what to use. I would think you would want something strong but not too strong?
Bullett is offline   Reply With Quote
Old 04-06-2014, 11:16 AM   #2
corvettejim1968
corvettejim1968's Avatar
Re: Interior door panel adhesive
use the 3m 77 spray. but you need to spay each side separately and let them sit for at least 2 minutes to make a proper bond before you stick the two surfaces together.
and make sure you thoroghly clean each suface before hand
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
