Old 04-06-2014, 01:27 PM   #1
dman1982
dman1982's Avatar
A dumb question...ish
So we hooked up the harness last night and wasn't able to get her to turn over from the key, we did get it to crank by jumping it, so good news is it's not locked up, bad news is no crank from the key...so the dumb question is does the grounds on the back of the engine have to be hooked up just to crank it?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-06-2014, 02:46 PM   #2
truckdude239
truckdude239's Avatar
Re: A dumb question...ish
are you using your orginal starter crank signal wire?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-06-2014, 02:47 PM   #3
dman1982
dman1982's Avatar
No, I'm using the one from the 2004 motor
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 02:48 PM   #4
dman1982
dman1982's Avatar
You talking about the one that goes from the battery to the starter right?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 03:01 PM   #5
truckdude239
no there should be a small wire with a ring terminal on it from the original harness on the truck it goes to the small post on the starter
David fuller
2000 Tahoe 5.3l 378
Old 04-06-2014, 03:02 PM   #6
dman1982
dman1982's Avatar
Oh, ya I put that on
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 03:47 PM   #7
truckdude239
there should also be a wire at the either the battery of an extra wire that bolts to the big lug on the stater that feeds power to the stock harness
David fuller
2000 Tahoe 5.3l 378
Old 04-06-2014, 03:49 PM   #8
dman1982
dman1982's Avatar
Ah...to 12 volt constant on the harness?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 04:28 PM   #9
ls1nova71
ls1nova71's Avatar
Use the purple wire that comes out of the bulkhead on the engine compartment side of the fuse box, that originally went to the old 350 starter. Dont use any part of the LS harness.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-06-2014, 04:33 PM   #10
dman1982
dman1982's Avatar
gotcha...i really appreciate that....havin trouble getting the fuel pump to purge as well
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:05 PM   #11
dman1982
dman1982's Avatar
now on my harness i have a purple wire that says starter, and then i have a purple one that comes out of the bulkhead...both goto starter? and will they go on the little post or the big post of the starter?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:06 PM   #12
ls1nova71
ls1nova71's Avatar
Do you mean it won't come on at all? Who did your harness? There should be a wire that needs constant 12v and some that need 12v switched, these should be hooked to an ignition relay that gets powered up by the wire that originally went to the HEI.
Old 04-06-2014, 06:07 PM   #13
dman1982
dman1982's Avatar
a guy from close by did my harness...im going to take a picture of what I'm talking about
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:10 PM   #14
dman1982
dman1982's Avatar
That purple wire there says starter, next to it is the purple wire from the bulkhead
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:15 PM   #15
ls1nova71
ls1nova71's Avatar
So the purple wire in the LS harness you connected to the one from the bulkhead and it didn't start? Did you connect the other side of the purple wire in the LS Harness to the starter?
Old 04-06-2014, 06:15 PM   #16
dman1982
dman1982's Avatar
i didn't see another end of the purple wire to the starter...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:19 PM   #17
ls1nova71
ls1nova71's Avatar
Well it has to be there and hooked up to the starter. Otherwise, just run a wire from the bulkhead wire straight to the starter.
Old 04-06-2014, 06:22 PM   #18
dman1982
dman1982's Avatar
Purple to purple got it cranking
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:29 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Sugar, water, purple; you were just missing the purple
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-06-2014, 06:29 PM   #20
dman1982
dman1982's Avatar
the pink wire from my relays thats for 12 volt ignition on goes to what wire on the bulk head? ya I'm a wiring dumb azz lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:29 PM   #21
dman1982
dman1982's Avatar
freakin hilarious
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:34 PM   #22
ls1nova71
ls1nova71's Avatar
Should be a heavy gauge either pink or red wire that originally went to the HEI.
Old 04-06-2014, 06:39 PM   #23
dman1982
dman1982's Avatar
theres a couple pink and red bigger wires
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 06:55 PM   #24
dman1982
dman1982's Avatar
and i should be able to hear the fuel pump prime up right? i got a walbro in tank pump
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-06-2014, 08:52 PM   #25
dman1982
dman1982's Avatar
had a grounding issue with the fuel pump, and had the wires hooked up backwards....working now...kinda...which wire is the ignition on?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
