Old 04-06-2014, 02:43 PM   #1
Neight
Neight's Avatar
CPP Front disc brake conversion photos
Anybody take photos while converting the front to disc brakes?
Neight is offline   Reply With Quote
Old 04-06-2014, 02:52 PM   #2
LVPhotos
LVPhotos's Avatar
Re: CPP Front disc brake conversion photos
Still running torsion bar front? It is just a matter of removing spindles install year correct balljoints for new spindles and the rest is standard brake job. The master cylinder has to be swapped out for dual chamber and if hydraulic clutch new mini cylinder. Pickle fork and sledge hammer. I believe CPP has tech article for this.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-06-2014, 06:23 PM   #3
Neight
Neight's Avatar
i got rid of the torsion bars and got everything i need for the conversion i got the master cylinder. right now im trying to remove the old spindle fron the upper ball joint. thats the part im stuck at
Old 04-06-2014, 06:58 PM   #4
LVPhotos
LVPhotos's Avatar
Pickle fork and hammer or air hammer.
