04-06-2014, 03:37 PM | #1 |
Doing body work and have question about shape of doors
I've finally got to the point on my 65 C10 that its time to do the finishing body work and I started to block sand the doors and I noticed that the front edge of both doors roll inward.
I placed a straight edge across the door and it's flat except for the front, the front edge rolls in about an 1/8 inch over a 1 inch span. The finder and door match up perfect at the top of the fender but the finder is proud of the door for most of the way down. Both doors seam to be the same. Is this the way the truck was original built? Thanks |
04-06-2014, 04:30 PM | #2 |
Re: Doing body work and have question about shape of doors
That's the way they were built. It's a ton of work to straighten that out to get the panels dead flush/flat, but it is possible.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-06-2014, 06:18 PM | #3 |
04-07-2014, 11:51 AM | #4 |
i have 2 66 trucks and they are both like that
04-07-2014, 11:56 AM | #5 |
They were made that way so that the fender and door wouldn't rub. If you do straighten them just make sure you have a good enough fender to door gap to clear each other. Nothing piss ya off faster then to get it all painted and open the door and chip the fresh paint!
1964 |
04-07-2014, 04:14 PM | #6 |
That was the way my 61 C10 was as well.
It's a fairly easy fix by dollying out the doors and fenders seperately. I did that to mine, pulled the doors off and dollied them out so that they would be just past the fenders. Then, rehung the doors and dollied them flush with the fender. A little body filler and they were straight. Time consuming, but worth it.... Also, my door skins were pregnant. Shrunk those as well so that the straight edge was flush against the skin from the back of the door all the way to the fron fender. Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
04-07-2014, 06:46 PM | #7 |
Who Me?
Mine were like that too.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
04-07-2014, 11:08 PM | #8 |
Perfect timing on this thread; I just starting blocking my 64 doors and noticed the same issue with the door edges........I guess I just saved myself lots of time leaving the edges as is.
04-08-2014, 02:18 AM | #9 |
The assy. manual gives actual specs for the front edge of the doors.
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
04-08-2014, 10:49 PM | #10 |
Astro...
Nice work on those doors. Door seams look good too, your hard work shows. Tom
