Old 04-06-2014, 06:53 PM   #1
airdale94
airdale94's Avatar
panhard/track bar
I'm in the middle of a 14 bolt swap and had a question about installing the panhard bar. I don't think I'm going to use the adjustable at least not yet. I'm just going to reweld the old bracket on the 14 bolt. Should I have the truck sitting on the ground (rear suspension loaded) or would it be allright to have it up in the supported on the frame (unloaded)? When I took it off the rear was hanging and I thought the bar would be under tension but it wasn't. So that made me think that it would be under tension with it sitting on the ground and free when the rear suspension was unloaded. Is that right? Any help would be appreciated.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-06-2014, 07:30 PM   #2
Willys47
Willys47's Avatar
Re: panhard/track bar
I think at ride hight you want it to be level and the axle centerd.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-06-2014, 07:50 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Its only under tension when you are going around a corner.
It should be level at ride height.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-06-2014, 08:07 PM   #4
airdale94
airdale94's Avatar
OK thanks! I will load up the rear and weld it up.
