oil pressure line - off?
hi - silly question but new to rebuilds.
I disassembled my interior to as I'm about to get some holes filled and primed and painted. for the gauge panel - I had to remove the speedo line and oil pressure line to take it off. question is - to get it to the body shop - can i run it without the speedo and oil line hooked up? no laughing please...well - a little is OK ![]() |
![]() Join Date: Mar 2012
Re: oil pressure line - off?
yes as long as the oil line is plugged or capped off
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Oct 2009
It will pee on your leg if you don't cap the oil line. Speed not connected is ok.
Its ok to run it with the spedo disconnected.But do not start it up with the oil pressure line unhooked you will have oil squirting out.You will have to get a plug for the end.
Hahaha no peeing please! I will cap it! Thanks guys u rock!
Thank u!
