Old 04-06-2014, 08:30 PM   #1
cwilkie
Chance
cwilkie's Avatar
TH400 Leak fixed..new problem. Please Help.
I was finally able to get my TH400 to stop leaking. It was the speedo housing o-ring and speedo gear drive seal. Well I replaced those and it stopped leaking. Great... So I thought.
After a few miles with a smile on my face I noticed my speedometer making a winding noise. I removed the speedo cable from the dash and the noise was still there but not too bad.
I thought it was the speedo so I grabbed a known working speedo from my stash and it still made the noise but not as loud. Next I removed the Speedo cable from the truck and removed the cable to clean and grease it. When I reinstalled it the noise was still there but not as bad.
I am leaning towards the speedo gear housing being the problem but visually the housing and gear look fine. It seals so no leaks.
Has anyone had a similar problem like this before.
I want to get this issue resolved because my 17 year old nephew has been asking me all winter to let him use my truck for his prom. Well I agreed and his prom is this coming Saturday.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 04-06-2014, 08:34 PM   #2
airdale94
airdale94's Avatar
Re: TH400 Leak fixed..new problem. Please Help.
You could have a kink in your cable. I wouldn't think if it was the gear that the sound would travel that much.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-06-2014, 08:43 PM   #3
cwilkie
Chance
cwilkie's Avatar
The cable it just the right lenth. I actually tried two. The th400 cable and another one I have laying in the the garage. The noise did not start until I put a new o ring and seal on the speedo gear housing. The are no kinks and does not appear to have any extreme bends.
This is a weird issue. Any help is greatly appreciated.
BB 396 w/TH400
BB 496 w/TH400
Old 04-06-2014, 10:46 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: TH400 Leak fixed..new problem. Please Help.
Try another cleaning-and-greasing. Sometimes heavier(or lighter) grease than that designed for it will work better. Is cable long enough to try a slight re-route? Try using nylon tie straps to shorten/reposition the sharper bends. HTH,
Sam
luvbowties is offline   Reply With Quote
Old 04-07-2014, 12:13 AM   #5
cwilkie
Chance
cwilkie's Avatar
I will try that. I am going to go get some white grease tomorrow. I will soak the cable in a coffee can with transmission fluid for a day and then coat in in white lithium grease then reinstall and hope for the best.
BB 396 w/TH400
BB 496 w/TH400
