Old 04-06-2014, 08:31 PM   #1
SchochCustoms
Cheap brake upgrades for 71 C10 front brakes?
So I've had this truck a few weeks now and the brakes have sucked for a while. Well, blew a tire over the weekend and when I took the tire off the brake rotor has a huge groove cut through the middle of it. It is REALLY bad.
So I ordered some 17" wheels and the stock brakes are going to look dumb inside there.
What kind of cheap brake upgrades are there for this thing? I know I can make my own brackets and find a way to mount some later model 2wd Chevy truck parts in there, but would be nice if someone already has that stuff to buy.
1986 S-10 Blazer 4x4 - rustbucket
2005 Chevy Trailblazer - wifey wagon
2005 Chevy Tahoe - family hauler
1971 Custom 10 Deluxe - shop truck
SchochCustoms is offline   Reply With Quote
Old 04-06-2014, 09:31 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Cheap brake upgrades for 71 C10 front brakes?
The 71-72 rotors had a groove in the center of them from the factory.
Look at this thread.
http://67-72chevytrucks.com/vboard/s....php?p=1514210
Keith
Convert to disc brakes.
Old 04-06-2014, 10:26 PM   #3
SchochCustoms
Learn something new every day!
Brakes still suck though. Maybe now that I know something isn't grinding I'll go ahead and fab my own brakes.
Old 04-06-2014, 10:49 PM   #4
mgchevyparts
mgchevyparts's Avatar
Factory 11.85" rotors with big piston caliper are pretty good brakes as is. I think you just need to get yours in proper working order to realize this. 11.85"-often called 12" are good size and will look fine behind 17" wheels.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 04-06-2014, 11:39 PM   #5
DreamRyder1963
DreamRyder1963's Avatar
The brakes on my 71 stop very well and they are stock setup. You might just need new parts.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 04-07-2014, 03:07 AM   #6
BlackedOut67shorty
BlackedOut67shorty's Avatar
Yeah, I had manual 67 stock brakes on mine and when I switched to discs from a 71 it was a night and day difference, just good pads and make sure there isn't any air in the system, might have to possibly adjust your brake peddle to take some slop off if it tends to be a bit sloppy.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 04-07-2014, 09:55 AM   #7
SchochCustoms
Didn't realize the brakes were that big, just assumed they were little old GM brakes. I wasn't paying much attention to the brakes, was just assuming a lot about it.
Once I get to working on it this week I'll probably go ahead and put new pads/rotors/calipers on it and change out the brake fluid. The crap is 43 years old, can't hurt to replace it all.
Old 04-07-2014, 10:21 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Did you change the master cylinder to disc/drum and the proportioning valve to match. Disc brakes require more fluid and pressure to actuate the calipers.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-07-2014, 10:42 AM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
You have good quality brakes, and everything is way cheap new. I remember replacing a caliper because a box of bleeders cost more. Make sure everything is clean, lubricated, adjusted properly and bled.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-07-2014, 10:51 AM   #10
engineer_gregh
engineer_gregh's Avatar
I would inspect the rear brakes. My stopping power drastically improved after reworking them. I had a bad wheel cylinder and didn't know it until I pulled the drum off.
engineer_gregh is offline   Reply With Quote
Old 04-07-2014, 10:52 AM   #11
SchochCustoms
It has factory front discs, the truck is all stock.
Old 04-07-2014, 10:55 AM   #12
SchochCustoms
I'm going to check them too, but the plan is to convert to rear discs.
Old 04-07-2014, 11:44 AM   #13
kvn1011
Kvn1011
kvn1011's Avatar
dupe post
kvn1011 is offline   Reply With Quote
Old 04-07-2014, 11:53 AM   #14
kvn1011
Kvn1011
kvn1011's Avatar
check out captainfab for the rear
i snagged the ImpalaSs rear kit
i just need to get the rear disc calipers and rotors from an impala and plum the lines
board vendor here
Old 04-07-2014, 12:01 PM   #15
67 chevelle
67 chevelle's Avatar
Defiantly replace your rubber brake hoses , 2 up front , one in the rear , they will be a problem if original .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-07-2014, 12:50 PM   #16
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I missed the year when I read the subject and saw brake upgrade I just assumed it was drums to discs.
Changing the brake hoses is definitely a plus. Did you get a good flow on bleeding?
VetteVet
Old 04-07-2014, 02:21 PM   #17
imjeff
imjeff's Avatar
Brakes gradually gain "suck" over time. The biggest maintenance items I have seen on older vehicles are flexible hoses, bad brake fluid and poorly adjusted drum brakes. It's amazing how big an improvement you can get with new fluid and rubber lines on these old trucks.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-07-2014, 03:40 PM   #18
GRX
GRX's Avatar
It's a GM thing. My '70 ram air GTO still had the original rotors when I bought it and they also had the so called cooling groove.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
