Old 04-06-2014, 10:55 PM   #1
jrigheimer
jrigheimer's Avatar
Big problem
Driving down the highway at 65 for about 70 miles, suddenly the oil pressure went to down to zero in about five minutes. Went for the exit and right before I got to it there was a pop and grinding noise, pulled over and there was a cloud of white smoke. white smoke came out of the air cleaner and exhaust. Tried to start it again and heard a grinding noise so I didn't mess with it.
Got towed to the nearest chevy dealer because everything was closed. what could this be, maybe a head gasket or oil pan. What caused the grinding noise. How did this happen in the first place. Will it be expense .
jrigheimer is offline   Reply With Quote
Old 04-06-2014, 10:56 PM   #2
jrigheimer
jrigheimer's Avatar
Re: Big problem
Also the water temperature was at 190 which it was the whole way but it was pretty hot out like 85
Old 04-06-2014, 11:12 PM   #3
litew8
litew8's Avatar
Re: Big problem
Sounds pretty serious, expensive.
possibly http://www.chevyhiperformance.com/te...s/viewall.html
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-07-2014, 01:04 AM   #4
C. M. Wolf
C. M. Wolf's Avatar
Re: Big problem
Oh yeah.. it sounds really 'not good'... and not cheap either.
Causes... ? Oil got too low and quit pumping, broke an oil pump & quit pumping oil, or lost oil through some kind of bad leak,(possibly a road impact of some kind, CA freeways are real good for that).
Anyways, the grinding was likely engine bearings far overheating & welding themselves together with friction... or in other words, I think your Chevy had a heart attack on the freeway... but the good news is.. a new engine can fix it again.
It could have been worse, I've seen hotrod Chevys go through something similar and the engine throw rods & pieces of heads through the hood at pretty high speeds... it doesn't sound like you'll have to do a lot of bodywork too..
Michael
C. M. Wolf is offline   Reply With Quote
Old 04-07-2014, 01:29 AM   #5
ho70
ho70's Avatar
Re: Big problem
jegs ebay crate 1200 bucks-I think your old engine has new issues that don't have a quick fix-sorry for the bad luck
ho70 is offline   Reply With Quote
