Old 04-07-2014, 10:41 AM   #1
monte0185
monte0185's Avatar
Dually Tires
What size, Brand and style is everyone running on their Dually's? I have 16" Alcoas on my dually and need new tires but cant decide on brand or style to go with. Kinda thinking cooper or goodyear but figured i would ask before i got a set. I do drive in my yard and prefer not to get stuck if its a little soft so i was kinda thinking an AT tire.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-07-2014, 11:17 AM   #2
83GMCK2500
Re: Dually Tires
My flatbed (the '96 in my sig) has a set of Michelin LTX M/S 2's in LT235/85R-16E on it that my dad bought, been a good tire, ride well, wear well. I've got over 50k miles on them and they are still quite usable, drove over some mountain passes this winter with just the weight of the bed and only needed 4WD a couple times.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-07-2014, 08:07 PM   #3
bilfman
bilfman's Avatar
Re: Dually Tires
I was in the same spot a while back, after some research the best bang for the buck I came across was kuhmo road venture a/t. I am very pleased with them they work well pulling, hauling, towing and off-roading. Hey my dually is a 4x4 after all .
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-07-2014, 10:07 PM   #4
monte0185
monte0185's Avatar
Re: Dually Tires
What size are you running? Wish mine was a 4x4. It would be alot taller if it was. LOL
Old 04-07-2014, 10:46 PM   #5
Chevy3+3
Re: Dually Tires
I'm running 235/85/16's on my 4x4 dually. I bought a set of of Kenda Klever M/T's. I've been very impressed with the tire so far. I think they make a set of A/T's as well. I got mine for $140/ea with free shipping.
Chevy3+3 is offline   Reply With Quote
Old 04-08-2014, 01:34 AM   #6
mrolds88
Re: Dually Tires
I have 245/75/16's on mine.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 04-11-2014, 08:38 AM   #7
Desert1957
Desert1957's Avatar
Re: Dually Tires
I run 235-85R-16's but you have to be careful about tires rubbing together. Some brands aspect radio is wider causing tires to rub and over heat under load.
Desert1957 is offline   Reply With Quote
Old 04-11-2014, 12:32 PM   #8
clapage6
Re: Dually Tires
I have alcoa wheels on mine and run the transforce HT 235/85/16E on the rear and same tire but in a 245/75/16 on the front. I wanted a wider tire on the front to help with flotation on the sand as my truck is used pretty much solely to haul my desert toys out to the dunes. I have 2 steelies that I keep a spare of each size on in this case. I like the transforce HT for the price
clapage6 is offline   Reply With Quote
Old 04-11-2014, 02:39 PM   #9
Chevy3+3
Re: Dually Tires
That's a nice slide in camper! You don't see many newer ones around. Especially piggy backin on a square, lol
Old 04-12-2014, 10:04 AM   #10
Desert1957
Desert1957's Avatar
Re: Dually Tires
Thanks...
Name:  P4290774 - Copy.jpg
Old 04-12-2014, 12:31 PM   #11
Cabnchassis
Re: Dually Tires
The khumo road venture a/ts are pretty good tires for the money. They aren't very aggressive treads so they don't compromise ride comfort or turning and they aren't loud. I run them in 225/75/16 on my 3+3.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 04-14-2014, 11:57 AM   #12
monte0185
monte0185's Avatar
Re: Dually Tires
Thanks for all the input guys. Love the Slide in camper desert1957!! Im thinking I might go with 215/85/16 or 245/75/16. Both have some decent tires to pick from and both are 30.5 inches tall so maybe my spedometer will be correct again. I desperatley need a smaller steering wheel too. Tried backing up my car trailer a few times the last couple weekends and trying to turn that semitruck of a steering wheel is a pain. Gives new meaning to give me 40 acres. LOL
Old 04-15-2014, 12:40 AM   #13
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Re: Dually Tires
I have 215 85 16 BFG Commercial TAs on my 83. They have been a great tire and weren't too expensive when I bought them
I just ordered the same size in Hankook Dynapro HT RH12s for my 89 R3500 Flatbed. They were really cheap at Discount tire and I just needed something to make it roadworthy rather than buying the best tire I could get. They do have good reviews, so time will tell.
If you are going to go wider than the 215s, you need to make sure your dual wheel tires aren't rubbing together under load like some have mentioned. They will get hot and blow out if they rub. People use wheel spacers to keep them apart to run the wider tires.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 04-24-2014, 11:58 AM   #14
83GMCK2500
Re: Dually Tires
Not sure if anyone else has experienced this, but I found it difficult to take decent pics of tire wear. These are the Michelins I mentioned with ~52k miles on them.
Devin
New Daily, the '96
Old 04-25-2014, 08:57 AM   #15
monte0185
monte0185's Avatar
Re: Dually Tires
Here is something that might help. Cant really tell from the pictures.
Old 04-25-2014, 10:34 AM   #16
83GMCK2500
Re: Dually Tires
Thank you monte0185, I have a picture similar to that saved. I am happy with my tire wear, it appears to be very even. (go figure, regular maintenance, alignment checks, air pressure...) I posted my pictures as reference to anyone looking at the Michelins as an option, they've done very well for me.
Devin
New Daily, the '96
