Old 04-07-2014, 10:48 AM   #1
jmader
jmader's Avatar
Does anyone have an original 327 engine in their 1967?
I'm having trouble figuring out what casting numbers I need for my rebuild. I'm looking for the intake, exhaust (4x4), and water pump castings. Mine is a GMC but I'm thinking the engines would be the same as a Chevy? Any info would be greatly appreciated!
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 04-08-2014, 11:49 AM   #2
jmader
jmader's Avatar
Re: Does anyone have an original 327 engine in their 1967?
Ttt
1967 Chevy SWB K10
Build thread-
Old 04-08-2014, 01:14 PM   #3
dmartin1
dmartin1's Avatar
i have a 327 in a 67 1-owner c20 i bought.had the rochester small square bore carb.
i can get numbers off whatever youd need if my stuff would be correct (2wd)
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-08-2014, 01:25 PM   #4
jmader
jmader's Avatar
The exhaust manifolds would be different but the intake and water pump should be the same I think. Yes if you could get those numbers that would be awesome!
1967 Chevy SWB K10
Build thread-
Old 04-08-2014, 08:16 PM   #5
19Chevy67C10
19Chevy67C10's Avatar
I have an orginial 67, 327 at our shop right now, it has ram horn exaust manifolds. I can get you parts number if needed..let me know..
Kev..
Kev's-C-10
19Chevy67C10 is offline   Reply With Quote
Old 04-08-2014, 08:39 PM   #6
jmader
jmader's Avatar
Kev..
Yes please. Any info would be great!
1967 Chevy SWB K10
Build thread-
Old 04-08-2014, 08:42 PM   #7
oldno7
oldno7's Avatar
19chevy67c10, could u put up a pic of those exhaust manifolds
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 04-10-2014, 11:44 AM   #8
jmader
jmader's Avatar
Ttt
1967 Chevy SWB K10
Build thread-
Old 04-10-2014, 03:41 PM   #9
dmartin1
dmartin1's Avatar
jmader, i replied in the other thread you have on original 67 327. posting here incase you dont see it.
65 nova
And more
Old 04-10-2014, 07:43 PM   #10
tlcrz1972
tlcrz1972's Avatar
Jeremy,
The exhaust manifolds that came off the engine I sent you are;
3747042
RH 43
3846559A
LH20
These came off the 1967 3/4 4X4 chevrolet truck with only 58,000 miles on it. I reasonably confident that it was unmolested and changed considering all the factory tabs were peened over nicely and didn't look as if they had been removed.
Hope this helps
Later Brian
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 04-10-2014, 08:40 PM   #11
jmader
jmader's Avatar
Hey Brian. Yeah I think you're right. Those were the manifold that were on my truck also. The engine was changed at some point but I think the exhaust was original. At first I didn't think so because when I looked up the numbers they kept coming up as corvette manifolds but I did find one place that said they were used on trucks. They have the smaller 2" opening which wouldn't be correct for a vette. I was pretty confident they were right and you are helping me confirm this. Thanks for you input!
1967 Chevy SWB K10
Build thread-
