Old 04-07-2014, 10:58 AM   #1
Rich916
Rich916's Avatar
Front brake issues
I have replaced my MC, prop valve, calipers/pads and rotors. Also all new hard lines and rubber lines.
The front brakes don’t appear to be completely releasing. I’m not aware of this when driving but after I park in the garage the smell and some smoke are apparent. I jacked the front wheels up and I couldn’t turn tire/wheel by hand, after everything cooled down, then I could turn by hand. Passenger side seems the worse.
Any help appreciated.
Rich
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 04-07-2014, 11:37 AM   #2
cdowns
cdowns's Avatar
Re: Front brake issues
have you adjusted the rod that actuates the master cyl to have 1/8" of free play
Old 04-07-2014, 01:47 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Agree ^
Had that happen to me.
There's a procedure to check this: http://www.classicperform.com/TechBo...ot.htm#pushrod
Forgot to add. Be aware that the MC has two different styles -shallow and deep piston and you have to use the right push rod.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-07-2014, 01:54 PM   #4
Rich916
Rich916's Avatar
I haven’t, So basically adjust the rod from the brake pedal that pushes into MC?
And adjust that so I have 1/8 inch free play. I will check later...Thank you
Old 04-07-2014, 02:01 PM   #5
Rich916
Rich916's Avatar
Originally Posted by 68gmsee View Post
Agree ^
Great article, Thank you. Looks like I need free play. freeplay allows the master cylinder piston to return to the "at-rest" position and prevents preloading the system.
