Old 04-07-2014, 11:10 AM   #1
Rich916
Rich916's Avatar
Dip stick tube leaks
Oil coming out from where the dip stick tube goes into the block. Replace or seal?
Any advice appreciated
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 04-07-2014, 11:19 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Dip stick tube leaks
I've done both but the one I sealed started leaking again. It could be I used the wrong sealer (?).
On the replacement, I bought a chrome one from auto parts and used a box end wrench that just fit over the tube to tap it in. So far that's lasted longer.
If it comes out easily you can try inserting something on the end of the tube to expand it slightly for a tighter fit, however, if the engine hole is wallowed out from someone messing with it before, it's touch and go.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-07-2014, 11:19 AM   #3
Either will help. It's just a friction fit. You could try cleaning and slipping an o-ring on or a dab of RTV I guess. A new one should do the trick,though,if you don't want to try the other fixes
Old 04-07-2014, 11:23 AM   #4
Lattimer
Lattimer's Avatar
I have used JB weld to seal that up before. Have to degrease it very well first.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
