Old 04-07-2014, 12:19 PM   #1
flashed
? About Sport Mirrors
Anyone had good luck finding a reproduction passenger side sport mirror that will adjust far enough to the left that you can use it ? I just installed a new one on my passenger door and it will not adjust so the driver can actually see anything .I bought some before that were fine .
flashed is offline   Reply With Quote
Old 04-07-2014, 12:46 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: ? About Sport Mirrors
Dont know exactly what your looking for but I just bought a pair of these for one my 72's... http://www.classicparts.com/1970-72-...tinfo/58-121/#
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-07-2014, 01:03 PM   #3
flashed
Have you installed them yet ,can you see from the passenger side mirror if you have ? I ordered a new one from SOKY and it is useless for the driver but great for the passenger to see out of .
Old 04-07-2014, 01:09 PM   #4
Steve Cole
Hey Flashed,
I'm in the same situation as you. I Installed a reproduction mirror in the factory location and can't see anything! I'm pissed! The same thing happened to me on a old Ford Falcon I restored, ended up using the original because the repo wouldn't adjust far enough. Should have known better.
If someone knows of a repo that you can actually use, PLEASE POST IT!!!
Steve Cole is offline   Reply With Quote
Old 04-07-2014, 01:13 PM   #5
Lee H
Lee H's Avatar
Is the issue you can't adjust it enough to see the rear fender?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-07-2014, 02:29 PM   #6
kcsa75
kcsa75's Avatar
Just curious. Did you actually receive the mirrors? I bought one from them at a swap meet a year or more ago. A couple months ago, went to the showroom to buy the other side and was told they have been on backorder for months and he didn't expect that they would have any more for a while.
I ended up going to LMC.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-07-2014, 02:29 PM   #7
flashed
Yes ,cant see anything close to the truck .
Old 04-07-2014, 02:38 PM   #8
Lee H
Lee H's Avatar
If you can see your quarter panel, or close to it while seated your blind spots are not covered. To adjust to get the blind spots covered, Sit in driver’s seat lean your head until it just touches window, adjust mirror until you can just see the rear edge of the rear quarter. Then lean inboard about the same amount, should be about centered in the car, and adjust the passenger’s side mirror. When viewing all three mirrors you want the smallest amount of overlap possible. It takes a while to get used to this however your blind spots will be all but eliminated.
Old 04-07-2014, 02:46 PM   #9
flashed
That is the problem ,mirror wont adjust in any more .
Old 04-07-2014, 08:06 PM   #10
Do the reproduction ones GM sold adjust properly? If so,then there will be some reproductions out there that work. Just have to find out who made which ones.
