04-07-2014, 01:48 PM | #1 |
4L60E/LS6 flexplate alignment issue
My swap:
CTS-V LS6 into '82 K10 SWB 4x4 mated to a 4L60E After debating with myself and brother over this, I decided to pull out the 700R4 and go with the 4L60E. Mind you this is after I had purchased the Advanced Adapters (AA) flexplate and adapter kit (the one used to mate Gen III engines to older GM trans.) I got a smokin' deal for a 4L60E from a totaled 98 GMC Jimmy for $250 (removable BH), the catch was, I had to remove it. Fast forward to install time... I removed the AA flexplate and adapter, installed a used flexplate that I was told came from an LS1 F Body. Ok so great, I went ahead and kept the donor transmission's torque converter, keep in mind it came from a 98 GMC Jimmy, a 4.3L V6. I figured all 3-bolt TQ's should have the same bolt pattern as any 3-bolt flexplate, well I guess I'm wrong because once the trans. and T-case were on the truck, it was a no-go!! The V6 TQ I kept from the 98 GMC Jimmy did not fit the "F-body" flexplate I slapped on there. It appears the bolt pattern did not match up. Another thing I noticed was the gap between the TQ's snout and crank's ass end take a look below. If you guys are trans. saavy, please chime in guys, I've beat my head over this, please let me know if I screwed by keeping the V6 TQ. Should I go and get a matching TQ/flexplate? ie. 2000's Chevy Silverado TQ/Flexplate combo? Any and all help is welcome!! Thanks. Last edited by LS-K; 04-07-2014 at 01:51 PM. Reason: added |
04-07-2014, 10:57 PM | #2 |
Re: 4L60E/LS6 flexplate alignment issue
I think you got screwed by getting a V6 trans in the first place. You need a V8 torque converter, but the problem is, a V8 converter won't fit the input shaft of a V6 trans....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-07-2014, 11:01 PM | #3 | |
Youre sh%*&ing me right?!! whats the spline count on an input shaft for V6's 4L60E? and for the V8's? |
04-07-2014, 11:03 PM | #4 |
I think I'm about to cry?....
04-07-2014, 11:09 PM | #5 |
bolt pattern is different, and Case on V6 type is one piece..not 2 piece like on a V8(removable Bell Housing)
v6 trannys have fewer clutch packs in them than the v8's The differences: Bellhousing. The only V6 bellhousing that will bolt to a V8 is one on a 4.3 liter transmission Input shaft. Pump stator tube. Torque converter. 2nd servo (sometimes). torque converter is different. It uses the short hub center Gen I SBC style converter You can use the 5.3L dished flex plate just need to add the spacer and elongate the torque converter bolt holes some. (although I'm personally not a fan of this) advanced adapters makes a flexplate/spacer kit for that swap PS: plan on replacing the 4L60e soon anyways... a stock v-6 TQ converter with a 4.3L 4L60e behind an LS6 will be destorying itself quite soon.
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
04-07-2014, 11:24 PM | #6 | |
If its of any benefit to my frankenstein set up i've got going over here, I still have the 27 spline count 700R4 TQ, what do you guys think? Will it be of any benefit to match that up with this 4L60E? |
04-07-2014, 11:36 PM | #7 | |
that being said... a few 4.3L 4L60e's DID have the same 2nd servo and clutch pack as a v8. *some* I don't know how to tell you that.(clutch pak/servo PN/s etc) But given a gen I SBC torque converter (4L60e) and vs a 700r4 tq converter.... a wash? An LS6 with any power adders will eventually eat up ANY 4L60e or 700r4 in time also. (I plan on eventually going thru mine when it explodes) Breath... it'll be okay.... and no it won't be *too* expen$ive whatever the solution is....
04-07-2014, 11:54 PM | #8 | |
04-08-2014, 12:10 AM | #9 | |
700r4 / 4L60e share same transfercase pattern... and drop side? if you want a quicker answer.... I would assume the pirate4x4 guys have seen this before with jeep 4.3L v6 swaps all the time. 2002 silverado 4x4 5.3L v8 search near your zip.... maybe? www.car-part.com/
04-08-2014, 03:23 AM | #10 | |
The 700R4 is a 4 bolt pattern. But all that was remedied with AA's 5040e adapter I used for VSS reasons. That adapter also makes up for the 4L60e's shorter length when compared to the 700r4. As far I know every 4l60e I've seen hooked up to a 4x4 was paired up with a driver side drop t-case. Don't quote me on that. It's just based on what I've seen. I think I'll be looking for a tranny on car-part here in Tucson. This sucks. This really hinders my motivation to complete this swap. |
