Old 04-07-2014, 03:56 PM   #1
TheSeeker
Shimming Alternator
I recently installed an internally regulated alternator and notice a whistling sound at idle, slightly metallic almost. After some inspeciton, I beleive it is coming from the pulleys/belt being SLIGHTLY misaligned. I will post some pictures for you all to make sure, but would this cause a whistling/whining sound?
My question is this: Can i shim or use washers to make the alternator come forward 1/8th-1/4 of an inch? Is this safe to do, and if so where would i shim or put washers? The best I can describe without pictures ATM is it looks like this (only diagonally of course)
WP and Ballancer is here
I
alternator pulley is here
I
Obviosuly I need them to be even
I
I
TheSeeker is offline   Reply With Quote
Old 04-07-2014, 04:07 PM   #2
suspect
suspect's Avatar
Re: Shimming Alternator
Go ahead and shim, It's safe. Hard to suggest where without pics.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 04-07-2014, 04:15 PM   #3
Wrenchbender Ret
You can bring the pulley forward a little by putting the lock washer in back of the pulley instead of behind the nut.
Wrenchbender Ret is offline   Reply With Quote
Old 04-07-2014, 04:38 PM   #4
TheSeeker
Ok thanks, that diagram didnt really post the way I meant it too haha, I will take a few pictures after work.
