removal of rear cab window
Can some one please tell me how to remove the rear window from the cab. There is a stainless steel trim around it and i do not want to damage it removing the glass, the window has an opening sliding window fitted. i have found a water leak from the window which is wetting the rear cab corners and causing them to rust.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
![]() Join Date: Apr 2011
Re: removal of rear cab window
I typed "rear window removal" into the Google search box at the top of the page and there were tons of threads, including this one:
http://67-72chevytrucks.com/vboard/s...d.php?t=536815 |
tcoop68
Razor blade just cut the lip inside the cab and it will come right out then take gasket off the window. Same with the front
cheers guys, i do not have a replacement rear seal so i need to get it out in one piece if possible. They are not available here so i will need to order one in next time i have a delivery from America
