Old 04-07-2014, 08:51 PM   #1
bigponystud
How to replace a bad fuel (gas) gauge 69 C10
Good afternoon everyone, I need help.
I have a 69 c10 and my gas gauge stopped working.
Does anyone have any instructions on how to replace it with a new one?
I have little to no experience on replacing gauges...so break out the big crayons!
Thanks from Tucson
bigponystud is offline   Reply With Quote
Old 04-07-2014, 11:54 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: How to replace a bad fuel (gas) gauge 69 C10
How does the gauge not work? Does it move at all or is it all the way full or all the way empty?
The first thing you need to do is determine if it's the gauge on the dash or the sending unit in the tank. Check the wire going to the tank sending unit to make sure there's no breaks. If it looks good remove the wire at the tank. The gauge should move to full then touch it to the metal part of the tank (ground). Needle should be reading empty.
Here's a site to read through: https://www.fillingstation.com/artic...ugetesting.htm
If non of the above and you're sure it's the gauge itself, you'll have to remove the gauge panel asm complete. Maybe someone has the complete instructions on how to do it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-08-2014, 09:44 AM   #3
bigmac73
bigmac73's Avatar
make sure your sending wire is plug into the fuse box, mine fell out on day while driving , i was like WTF??? guess i hit it with my foot or something
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
