Old 07-27-2003, 11:59 PM   #1
casey
casey's Avatar
question for the diff experts
my son bought two diffs for his 77 ford 4x4, for 150.00 there 410's, heres the confusion for me the rear is 37 crown 9 pinion=4.11111111 the front is 45 crown 11 pinion=4.090909 does it matter if there not exactly the same ratio, i was going to put the rear diff together myself cause the gears come out assembled, just have to pull the axels, it looks like it a limited slip or posi, how can I tell, one more question how do you change axel and pinion seals, thanks for the help
casey is offline   Reply With Quote
Old 07-28-2003, 01:28 AM   #2
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
That difference in ratios is really common, and that's why I will never run in 4wd on a hard surface. I've even run as much difference as 5.29 in one axle and 5.38 in the other. nothing to worry about.
If it's got any kind of springs or pretty much anything but 4 bevel gears and a cross shaft inside the carrier it's probably got a limited slip.
I can't remember how to change the seals on a ford rear. they aren't the simple c-clip like my chev.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 07-28-2003, 01:29 AM   #3
Blue_71
Bloo
Blue_71's Avatar
.02 wont affect anything, its when you get into putting like for instance 4.11 and 3,73 together
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-28-2003, 02:58 AM   #4
casey
casey's Avatar
have you guys ever pulled axles and just put them back in with out changing the seals
