Old 04-07-2014, 10:59 PM   #1
cleansquare
Need a good helper airbag setup for tow/haul
Hey guys, since I raised th front of my c20 2" to level I now get really bad sag in rear when towing rv or boat. I knew this woukd happen and have nk refrets as I love the look of a level unloaded truck.
What I want is a good helper bag setup rated for my truck, to sit on the rear 14 bolt rear, or however they mount. Its an 85 3/4 ton camper special. I'm not Interested in one with a compressor to air up on the go, I can air it up with a small portable compressor ill carry in my truck.
Anyone got any advice, pics or links? Thanks!
cleansquare is offline   Reply With Quote
Old 04-08-2014, 02:26 AM   #2
andrewmp6
Re: Need a good helper airbag setup for tow/haul
Look around http://www.airliftcompany.com/ they have a kit that is just the bags and mounts.Then you can get normal air lines and schrader valves from one of our air ride venders on here.
andrewmp6 is offline   Reply With Quote
Old 04-09-2014, 09:04 PM   #3
72MARIO
72MARIO's Avatar
I have used the 5000lb air lift kit on my 1967 C20. For my truck I had to modify the upper frame bracket. Your truck will be easy just drill a few holes. I have used it flawlessly for 5 years in my work truck used for roofing.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-10-2014, 08:27 AM   #4
CHRIS67GMC
CHRIS67GMC's Avatar
Here is a link http://www.summitracing.com/parts/fi...1985/model/c20
CHRIS67GMC is offline   Reply With Quote
