![]() Join Date: Jan 2002
292 lower radiator hose part number?
Anyone have a part number for lower radiator hose for a 292 in a four wheel drive that actually fits? I bought one from rockauto and one from classic parts but neither of those fit. I did get the flex hose from O'reillys but don't care for it.
thanks in advance.
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
![]() Join Date: Feb 2002
Re: 292 lower radiator hose part number?
Gotta work tomorrow or I'd go out and check it for you. I use a flex hose on the upper Radiator/Thermostat part, but my lower hose is 292-specific. I don't know if the K- trucks used a different hose from the C- trucks. Maybe tomorrow night, I can check.
Well I checked out my lower radiator hose and could find no markings on it. Sorry.
![]() Join Date: Nov 2001
Gates lists:
1969-1972 Chevrolet C & K Series 292cid Gates 20489 here is a a couple links: http://navigates.gates.com/Parts.asp...e=Light+Trucks http://www.autopartsandstuff.com/search.aspx?find=20489 What part number did you get from Rock Auto?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Thanks guys. That is the part number for the hose I got from Rockauto that doesn't fit...I have the flex hose in there for now,so guess will keep looking
Do you have a different radiator than originally stock?
In what way doesn't it fit?
Before I put the AC on my 292, I snagged the compressor brackets off a 70's, Nova with a 250. None of that overweight, bulky junk was of any use, but it did show me that a car with 250 and AC used a longer hose with some extra kinks to go behind one of the AC braces. I just looked at O'Reilly's web page and they show only one lower hose for '74 Nova with 250 and no notation for AC or not. They have part # 20390 and say it is an inch longer than the the one for 250/292, C/K trucks. It may be worth looking at.
'67 GMC 2500, 292, 4spd, AC |
