04-08-2014, 12:51 AM | #1 |
Replacing stock A/C compressor with a Sanden A/C Compressor
I was going to go with a vintage air setup but seeing I have a new Sanden compressor and mounting bracket I was wondering if anyone have done this? thanks Rick
04-08-2014, 10:20 AM | #2 |
Re: Replacing stock A/C compressor with a Sanden A/C Compressor
I have not, but that has to be a very common swap. The Sanden compressor is much more efficient than an A6. Why do you ask?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-08-2014, 12:55 PM | #3 |
sanden is a great compressor , if you can get the lines to hook up and get it mounted it will work great....I put one on ole dollor but mine is an add on a/c not factory..
04-08-2014, 01:57 PM | #4 |
I have a sanden compressor on my truck but also using vintage air and it works great no problems at all
04-08-2014, 04:54 PM | #5 |
I have a Sanden compressor and Vintage Air condenser on my truck, which is otherwise all factory air. It works just fine. I converted to R134a, which meant adjusting the POA valve and new refrigerant hoses too.
1971 C10 Longbed, 350/TH350 |
