Old 04-08-2014, 02:34 AM   #1
cstm68
cstm68's Avatar
5.3L rattle at freeway speeds?
On my 01 z71 with a 5.3l I can here a rattle noise that sounds like it is coming from the engine. I can only here it with the windows up and the radio down. It only happens at speeds above 50. Any ideas?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-10-2014, 12:25 AM   #2
cstm68
cstm68's Avatar
Re: 5.3L rattle at freeway speeds?
Any ideas?
Old 04-10-2014, 12:27 PM   #3
Special-Ed
Special-Ed's Avatar
turn up the radio, or give us more details...
having a rattle at highway speeds is like saying my car wont start...
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 04-12-2014, 02:15 AM   #4
cstm68
cstm68's Avatar
It is a dull rattle when the radio is turned off. When I'm next Tina jersey barrier or wall I can hear it louder with the windows down. Replaced u-joints, rebuilt transfer case, checked and serviced both diffs and i put it in neutral and shut the motor off and still heard it both huns are new and I pulled the cv axles and still heard it.
Old 04-12-2014, 05:00 PM   #5
Special-Ed
Special-Ed's Avatar
are you sure its not some kind of exhaust rattle or heat sheild?
could be a brake pad
seems like you did a lot of work to track down a rattle
Old 04-12-2014, 09:27 PM   #6
stroker87
I know alot of guys replace a bearing in the steering column sounds like a ball bearing vibrating my truck does it now and then about 2500 rpms it was a common problem with the 99 06 trucks
I dont remember the details you should be able to google it
stroker87 is offline   Reply With Quote
Old 04-12-2014, 10:05 PM   #7
Special-Ed
Special-Ed's Avatar
it could be the flex plate?
