04-08-2014, 08:52 AM | #1 |
5.3 cam question vinci ultra torque
Looking at a Vinci ultra torque cam for my 5.3. Anyone tried these? Can I run stock valve springs?
DUR @ .004" 272*/280* DUR @ .050" 210*/218* LIFT .551/.551 LSA 116* Here is a link to their page http://www.vincihighperformance.com/...s%20truck.html |
04-08-2014, 09:59 AM | #2 |
Re: 5.3 cam question vinci ultra torque
no on the valve springs.
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
04-08-2014, 11:26 AM | #3 |
ls6 springs are cheap and should work fine with this cam. I would make that swap at a minimum.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-08-2014, 12:36 PM | #4 | |
For that price you can get a custom cam ground. Any reason you want that one specifically?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-08-2014, 01:32 PM | #5 |
good point I did replace mine with harden pushrods when I did the cam swap.
04-08-2014, 03:30 PM | #6 |
Not dead set on using Vinci. Just looking for a mild cam that will give me a little sound/ torque over stock and keep my fuel mileage
04-08-2014, 07:19 PM | #7 |
meowMEOWmeowMEOW
go over to ls1tech in the used section and pickup a takeout z06 cam and ls6 springs. easy cheap power, under $250 and very driveable
04-09-2014, 10:49 PM | #8 |
I just got the vinci trucker cam, i havent installed it yet. Im taking out the z06 cam and probably the ls6 springs.
