Old 04-08-2014, 09:06 AM   #1
88Ironduke
I-6/250 with CS alternator ?
So I have a nice CS alternator that had the right price tag, free. Its a pretty chrome unit but alas all things come with a price of some sort.
My question to the inline six gurus is about the mounting of the alternator. My truck did not have its original externally regulated alternator in place when I brought this home. But with the original single groove water pump pulley it was clear that the new CS style alternator does not line up with the groove on my stock water pump pulley. Did the inline 6's ever come with a lower alt mount that pushes the alternator further forward on the block?
I have a installed what I think to be a SBC water pump pulley for illustration purposes. The inner/aft groove lines up nice on the alternator and drive pulley on the crank. The outer/forward groove is where I should be at in a perfect world. Technically a guy could easily make this work, but its a smaller diameter pulley which would in turn drive the water pump fast than stock....
My fear is the coolant would be moving too fast and possibly cause an over heat condition due to coolant not having enough saturation time to pick up heat in the block. Or it would cause premature water pump failure.
Penny for your thoughts....
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 04-08-2014, 03:17 PM   #2
TheSeeker
Re: I-6/250 with CS alternator ?
I beleive that the alternator mounts in front of the bracket, bolt through the back. It appears that your pulley alignment is a tad off in this picture, but if you mount the alternator with the tab in front of the bracket, it might even out?
TheSeeker is offline   Reply With Quote
Old 04-08-2014, 04:20 PM   #3
68gmsee
Active Member
68gmsee's Avatar
It's always a pain trying to line up accessories on these old trucks but I doubt you will have any heating/cooling problems using the inner pulley. The thermostat should be able to control the water/engine temp.
If it is a serious worry, try to locate one with same size pulleys.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-08-2014, 04:38 PM   #4
88Ironduke
Thanks guys. I tried moving the top bracket around and it seemed to drop in the best at its current position. However I will adjust/shim accordingly. My hope was to find a guru that may have done this swap on a 250 or even 292. Its still early yet.
88
Old 04-08-2014, 05:21 PM   #5
TheSeeker
I just installed a 12SI alternator type on my 250, and am having alingment issues as well. I had to shim the alternator forward to make it line up on the inner groove.
