Old 07-28-2003, 12:40 AM   #1
sixty8chev
The Sauz
sixty8chev's Avatar
drip rail goo?
I'm finally going to be getting around to painting my roof white and i was just wondering about stripping out my drip rails.
Theres a bead of silicon? under the paint, its all cracked
and its gotta go,
but i was wondering what it is and if it needs to be re-applied before i paint?
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 07-28-2003, 12:43 AM   #2
68 Suburban
68 Suburban's Avatar
3m makes something.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-28-2003, 12:46 AM   #3
casey
casey's Avatar
go to your local auto paint store they will fix you up with the right stuff, I did mine I think it was called seam sealer, all I remember is it didn't have a very long working time, cause you have to smooth it out nice, I would make sure you strip out all the old stuff
casey is offline   Reply With Quote
Old 07-28-2003, 08:12 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I used 3-M's Fast-n-firm. Comes in a tube you use in a caulking gun. (about $10)
It dries hard and works great in that location. The only problem I had with it was using it on the rear seam on the roof above back window. Mine developed a crack now so im re-doing it again and repainting. I think it's just too thin in this area and that's why it cracked. ???
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-28-2003, 08:23 AM   #5
Tuck
After you put the seam sealer on , to smooth it out , use laquer thinner in a spray gun, and while its wet smooth it out with your finger. Mine is perfect.
To get the old craked stuff off , use a wire wheel on a drill.
Tuck is offline   Reply With Quote
Old 07-28-2003, 09:46 AM   #6
68_c10_on20s
68_c10_on20s's Avatar
good advise guys
im fixen to paint my roof as well and was wondering the exact same thing thanks for all the info
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 07-28-2003, 09:50 AM   #7
nosto
Flamin' Bass
nosto's Avatar
3M has a couple of products -
04226 Duramix urethane,
????? Automix - self leveling 2 part epoxy
I went with an Automix-type of product. It went on easy and smooth. Only problem was the vertical parts of the drip rail behind the doors. It sorta dribbled down to the bottom and on to the cab. Have to apply it a little at a time here.
This stuff required a special dual cartrige gun that my vendor let me buy, use and return. I needed to touch-up some spots after I had returned the gun, so I just squirted the stuff into a ZipLoc baggie, squished it around, cut a small hole in one corner, and squeezed it out. Worked pretty good, except that it got HOT!!!! Hot enough to burn your hands, so I used gloves the next time.
My $0.02 on Fast-n-Firm:
Had bad luck with it. Used it on a fender to body seam, then painted. The stuff cracked 3 weeks later. An old body work guy said not to use it anywhere you might expect the body to flex, even a little, because the F-n-F cures rock hard. Look for something that stays flexible.
Good Luck,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 07-28-2003, 10:07 AM   #8
SLS
Finish the'71..or bust!
SLS's Avatar
3M Heavy Drip-Check Sealer
SLS has attached this image:
An off-white, paintable, fast drying, flexable rubber base material that seals small cracks and other openings, such as drip rails, molding, cowling and welded seams. Heavy consistency makes this sealer especially suitable for vertical seams.
Remove all dirt, grease or foreign material. Apply sealer at least 1/16'' thick. Sealer must be thoroughly dry before painting. Clean up excess with lacquer thinner. On freshly painted surfaces allow sealer to dry thoroughly dry before removing excess. On old paint, glass, metal, ect remove excess sealer before it drys.
And like 'tuck' said...a wire wheel on a drill removes the old stuff quickly and use laquer thinner to smooth the new sealer out. It is VERY tacky at application...but sets up quickly.
Have fun!
SLS is offline   Reply With Quote
