Bellhousing for a 62 ( which one)
I am looking at buying a 1962 chevy truck. It has a 235 and a manual trans.I want to swap to the later 250-292 six. The bellhousing is not the same.I know that the V-8 bellhousing and the late six is the same -as is the flywheel starter etc.
The problem is the slave cylinder on the clutch mechanism. Will this bolt up to any 60"s v8 bellhousing or is it specific to the 60-62 . If so which bellhousing?I really want to stay six cylinder power - just go to the later version. LMD |
Re: Bellhousing for a 62 ( which one)
Do you plan to keep the hydraulic clutch or go mechanical?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#3 | |
or convert over to having the hydr. on the left side. if you are going to p/brakes see capt fab as he has a hydr clutch master setup to go with it ron |
Here are a few photos of the cast iron bell housing with the hydraulic clutch on the passenger side. You can see the two bolts that hold the "slave" in Photo #2 The bottom photo was a "before" photo and the top 2 photos are "after".
As you can also see in Photo #2, this bell housing has the mounts built into it and was basically a "plug and play" with the original crossmember. Originally, this was bolted to the original "granny low" transmission. The transmission shown is the NP440/MY6 from the 1980's trucks. The bolt patterns for both of these transmissions were the same. Hope this helps... Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
Thanks guys very helpful. Need to find me a 60-63 v8 bell housing in guess if I am going to look into this truck.
Thanks again. Lmd. |
Best of luck on finding that bellhousing, I've been looking off and on for some time without much luck or just flat didn't want to pay the rediculous price some people asked. I'll probably end up going with the Novak setup myself. The only casting number I know of is 3765710.
But hey, if you find a pair of them let me know!!! |
I could be wrong, but I think the bell housing you want is common in some of the other GM cars of that era...I don't think it was just for the trucks.
Maybe someone else can chime in on that...
you will find them also in medium duty trucks
ron |
60-66 Nut
![]() ![]() Join Date: Mar 2007
There are a couple ways aside from the '60-'62 V8 bellhousing. One would be to use the standard '63-'67 bellhousing with a hydraulic clutch conversion from Novak. You could use the '68-'72 bellhousing with an adapter ring for the trans input bearing retainer. Second would be to use a '84-'91 bellhousing, which are setup with a hydraulic clutch. The issue with this is that you will have to remove the bellhousing crossmember and add a trans crossmember. Thirdly you could do away with the hydraulic clutch and convert to mechanical.
How hard is it to convert to mechanical? I have a bellhousing pivot bar from the bell housing. I can get the timy bracket no problem what else is required?
Thanks. Lmd. |
I have a complete set of mechanical linkage coming off a 63 in the next few days...will need a home.
Yes, I also would be curious on what entails and what years are compatible for converting to mechanical linkage.
#13 |
#14 |
But Found Her 25yrs Later!
So what's so unique of these that make them so expensive?
http://67-72chevytrucks.com/vboard/s...d.php?t=670324
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#15 | |
'62 C10 LWB fleet side. 283 w/ a T5 |
#16 |
Post over in the wanted section. Those bells are out there,I found one last week on here in just a few minutes.
#17 |
![]() Join Date: Oct 2006
Not trying to hijack.... my 60 has a 250 with hydraulic clutch (on the left side)
isn't the 250 bell housing the same as the v8's
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#18 |
How about a hydraulic bearing? I would trade out my bellhouse for lighter race aproved one since I am going this route.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#19 |
I do have one of those bellhousings sitting in my back yard attached to a 283 block. Has the hyrdaulic clutch setup on it.
#20 |
![]() Join Date: Feb 2017
#21 |
