![]() Join Date: Aug 2011
Flywheel Bolt locks
All, does anyone know where to get new flywheel bolt locks or is this something you make? 1951 AD
Thanks Pat
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
Re: Flywheel Bolt locks
IMO, a little red Loctite during assembly is better than any bolt lock ever made....unless you're compelled to use them because of a restoration thing. The fact that they bend means they are reasonably soft and the LAST thing one needs under a hardened, torqued bolt is a soft washer.
Thanks, I'll go with the Red Lock Tite
Pat
When they came into use Lock tite hadn't been invented yet. A star lock washer and a dab of lock tite would suffice though. Even hardened machine washers and the lock tite would be ok.
