Old 04-08-2014, 08:59 PM   #1
AustinBelair
So I only have 3 options for tubular control arms?
CPP, Ridetech or DJM for tubular?
I've read bad stuff about the DJM, the CPP are a little expensive for me and my pops and the Ridetechs are way too expensive.
Anything else out there?
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 04-08-2014, 09:06 PM   #2
67swb72klb
67swb72klb's Avatar
Re: So I only have 3 options for tubular control arms?
Hotchkis but they are a little on the high side too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-08-2014, 09:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Porterbuilt would be my only choice.
Rebuild your stock arms WAY before DJM.
Keith
Convert to disc brakes.
Old 04-08-2014, 09:14 PM   #4
AustinBelair
Yeah I was in the process of rebuilding the stock ones but the lowers look like they might have been damaged once upon a time.
The Porterbuilt arms are sexy but there's no way I'd spend $1100 on control arms.
Old 04-08-2014, 09:38 PM   #5
PGSigns
PGSigns's Avatar
There is Michigan Metal works. Some better pricing on Summit and jegs, Classic parts, and performanceonline.com.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-08-2014, 11:07 PM   #6
YBNORML
YBNORML's Avatar
I just went through this. The best option out there is the PorterBuilt stuff. I know that there is cheaper options but you get what you pay for.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-09-2014, 12:01 AM   #7
Pro Performance
Pro Performance's Avatar
What are you wanting to achieve with the arms? Looks? Better performance? Easy adaptation to bags?
Do keep in mind, that you can purchase just the lowers from Porterbuilt. For example, if you are running a static dropped truck, you can get the lower 1" forward and keep factory uppers. This will give you more caster up front and position the wheel in the opening a little better. Just the lower with coil spring adapter would be $698.
- Travis
Pro Performance is offline   Reply With Quote
Old 04-09-2014, 12:55 AM   #8
AustinBelair
- Travis
I was actually looking at uppers. Looks and just wanted some more camber adjustment. Does PB sell just uppers?
Old 04-09-2014, 01:08 AM   #9
Pro Performance
They sure do, and run $400 for the pair.
Old 04-09-2014, 01:27 AM   #10
AustinBelair
Hmmmm! Damn the CPP ones are $325. I've got to see if I can afford the extra.
Old 04-09-2014, 09:18 AM   #11
SCOTI
SCOTI's Avatar
What bushing type does CPP use? Poly? I recall PB's use Delrin.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-09-2014, 10:34 AM   #12
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I have some stock arms if you are interested in those?
chevyguy_72 is offline   Reply With Quote
Old 04-09-2014, 04:46 PM   #13
Madmartigan
Michigan Metal Works makes quality arms at a great price. I know you said tubular but give them a look. The flat plate uppers are $149 pair. They will also make you tubular if you want.
Madmartigan is offline   Reply With Quote
Old 04-09-2014, 06:07 PM   #14
SCOTI
SCOTI's Avatar
Just read through the ordering process carefully. MMW doesn't do shock mounts unless specified (apparently). Not sure what else so make sure you ask questions....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-10-2014, 03:26 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
That price is also WITHOUT the cross shafts...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-10-2014, 09:58 PM   #16
AustinBelair
Do I order them from you?
Daniel
Old 04-10-2014, 10:04 PM   #17
Pro Performance
Daniel,
Yep, sure can. Just give me a call tomorrow, and can get it all going.
480-420-8175, 9-5 Arizona time.
Thanks,
Travis
Old 04-30-2014, 08:53 PM   #18
AustinBelair
Great talking to you, Travis. Can't wait to get those Porterbuilt arms.
Old 04-30-2014, 11:16 PM   #19
Pro Performance
Same here, and thanks for the order!
I will keep you posted when they are on the way.
Old 05-01-2014, 06:28 AM   #20
bbbc10
Diggin The SquareLife
they use stock crossshafts
bbbc10 is offline   Reply With Quote
Old 11-02-2015, 09:24 PM   #21
ol_skool_chevy
ol_skool_chevy's Avatar
I looked at Porterbuilt stuff....Top notch stuff. I was all ready to order till i saw the shipping cost...
I passed on it.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-04-2015, 01:58 PM   #22
Stained Soul
Post some pictures up when you get them please.
Stained Soul is offline   Reply With Quote
