04-08-2014, 11:46 PM | #1 |
Headlight Foot Dimmer switch wire pigtail?
Howdy folks! does someone make a replacement for the three-wire pigtail / partial harness, with the three-position connector for the foot operated headlight dimmer? Mine (in my 72 Blazer) is a crispy melted and rusty mess:
04-08-2014, 11:54 PM | #2 |
Re: Headlight Foot Dimmer switch wire pigtail?
I think I've seen them in the "Help" section of the parts store. I believe there are two styles to fit two different dimmers. As I recall I believe I may have changed the dimmer switch to match the plug I found.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
04-09-2014, 12:05 AM | #3 |
Try American Autowire. I think they reproduce them.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
04-09-2014, 12:06 AM | #4 | |
JEGS Performance Products 11125K GM-Style Floor Mount Dimmer Switch & Wiring Pig GM-Style Floor Mount Dimmer Switch & Wiring Pigtail Kit Includes 555-11125 & 555-11126 |
04-09-2014, 12:10 AM | #5 |
All Vehicles > CHEVROLET > 1972 > K10 PICKUP > 5.7L 350 cubic inch V8 > Electrical-Connector > Dimmer Switch Connector
Found it at rock auto...they have a couple different ones. Depends on whether you want to spend $2 or get the other one for $3!
04-09-2014, 12:11 AM | #6 | |
Jeff
04-09-2014, 12:13 AM | #7 |
Thanks again Jeff. I have a rock auto list going as well!
04-09-2014, 12:23 PM | #8 |
Good you found one. I was going to say painless has most of
The original connectors as well. Not sure if they sell separate From the kit But they claim all original Connectors to keep stock components.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
