Old 04-09-2014, 08:41 AM   #1
norm roll
norm roll's Avatar
Tire and wheel question for my step side
whats the widest tire and wheel that will fit a 66 step side short bed stock width rear end. the truck is lowered 2 in in the rear.
also what about the fronts I may also lower the front 1 to two inches
thxs norm
norm roll is offline   Reply With Quote
Old 04-12-2014, 12:23 PM   #2
norm roll
norm roll's Avatar
Re: Tire and wheel question for my step side
anyone
Old 04-12-2014, 01:49 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I have a 1960 and I'm running 255-70-R15's on the rear, mounted on 15x7 American TTO's. My truck isn't lowered, but if I did these would just squeeze up inside the fenders. I believe the rear end in a 66 is at least an inch wider than mine. Unless the fender opening is above the tire, there isn't very much room in these fenders compared to a fleetside, because the 60-66 bed and fenders were designed for the 55-59 trucks which are much narrower.
I've seen guys run 10" rims and 50 series tires on these stepsides, but I'm not sure how much tire rubbing goes on either at the fender, or on the back side at the bed wall.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-12-2014, 02:18 PM   #4
taclem
taclem's Avatar
I am running 275-60-R15's stock height wouldn't want to run much wider, they are just off the inside edge of the box. I am running 15X8 Ansen Sprints. I also am running a 1976 bed.
taclem is offline   Reply With Quote
Old 04-13-2014, 08:09 AM   #5
msaelens66
I have BFG 295/50/15, they do not fit inside my 64 step. Wheels are US wheel 15/8 Stealth 4" backspace. They sit flush with outside of fender. I knew that they wouldn't ,but they were free. We run air shocks to raise it up enough temporarily as my son wants a different tire/wheel setup down the road.
msaelens66 is offline   Reply With Quote
Old 04-13-2014, 10:52 AM   #6
63burban
Chevy addict
265/70 15" on 15x8 rally wheels, they are close but never rub even with a load.
63burban is offline   Reply With Quote
