Old 04-09-2014, 09:23 AM   #1
Slammed84
Slammed84's Avatar
84' Dash/Vents Installation
Needing info on the proper way to install all the dash vents and ducts on an A/C cab.
I need to know if I am missing any pieces, and whether the vents have to be attached to the dash before installing the dashpad.
The heater box as well as the ducts for the defrost vents are already installed under the dash.
I'll post all the pics I took of what I have as of right now.
I think I am missing the hose from the long duct under the column that routes to the driver side vent. Or is there a hose on that side?
I'm assuming that the plastic pieces that go behind the vents have to be attached onto the dashpad before installing the dashpad, correct?
Also it looks like the upper vent on the bezel isn't going to line up very well with the duct that is under the dash, is something backwards there?
I can take more pics if needed.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
