Old 04-09-2014, 09:29 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
cnotch
how much can i c-notch my frame without cutting into the bed?any suggestions please.my plans are to go air ride suspention front and back thank you.
1966FLEETSIDE is offline   Reply With Quote
Old 04-09-2014, 09:42 AM   #2
PGSigns
PGSigns's Avatar
Re: cnotch
Any of the bolt in notches will work. There is a thread going now in the suspension section on notches and some good install tips in it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-09-2014, 10:42 AM   #3
Robert Haas
Re: cnotch
When you quit making sparks and start making splinters back up an inch or so
Robert Haas is offline   Reply With Quote
Old 04-09-2014, 12:29 PM   #4
LVPhotos
LVPhotos's Avatar
Re: cnotch
I just got the pipe notch done on my '62 with 2" the 12 bolt will be right on the wood aired out.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-09-2014, 01:25 PM   #5
NEWFISHER
NEWFISHER's Avatar
Re: cnotch
BAWAHAHAHHAHAA
I did this and worked well. You are limited on the pumpkin hitting the bottom of the wood as mentioned. Some have cut an opening in the bed floor center to allow the pumpkin to travel into the bedspace and take full advantage of a deep notch, but you will end up with a speed bubble, leather cover, flipped diff cover etc to make it look decent.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 04-09-2014, 04:26 PM   #6
familyfast64
familyfast64's Avatar
Re: cnotch
I wouldn't go much more than 3" inro the frame. Unless you want to step the frame. up into the bed. You want to save enough metal on the sides of the frame to weld or bolt some plate too. My cpp notch is 3" deep. I chose to go that route rather than build my own simply because our frame is "S" curved right there and I thought the time saved was worth paying a lil more than material cost. Not that I'm right that's just what I chose being a passionate novice. Lol since your bagging tho,I would maybe consider stepping the frame. I am static and really only needed an extra inch just to be safe.
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-09-2014, 11:43 PM   #7
1966FLEETSIDE
Re: cnotch
cool thx for the input,i will certainly give it some thought.
