Old 04-09-2014, 10:13 AM   #1
ochre70
Does this look right to you?
I'm convinced the front of my truck is lower now than it was with 1" drop springs and 2 1/2" drop spindles. All I've done is put new stock height springs in it. Any thoughts?
1970 Ochre & White C10
ochre70 is offline   Reply With Quote
Old 04-09-2014, 10:23 AM   #2
ochre70
Re: Does this look right to you?
Should I have gone with a HD spring? Truck has a 350, a/c, ps and PB.
Old 04-09-2014, 12:03 PM   #3
ochre70
ttt
Old 04-09-2014, 12:23 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Looks correct to me...The tire itself looks rather tall from rim to tread and factory springs seem to sag a bit after 40+ years of use. I'm running 275/R60/15 BFG's all around and I had to pull the 2" drop springs and reinstall the factory coils with 1/2 a coil cut off with the 2-1/2" drop spindles to get the wide 28" tires to clear the fender opening...So I wound up with a theoretical 3" to 3-1/2" drop. That tire appears to be taller than 28" so yeah, it looks about right considering the 2-1/2" drop spindles are still in...After looking again, that tire appears to be at least a 30" tire maybe taller...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-09-2014, 12:32 PM   #5
ochre70
Tires are 235/70-15's. I think that's around 28" tall. Springs are new too. They are the standard duty versions and the truck looks like its sitting the same if not lower...
Old 04-09-2014, 12:54 PM   #6
Ironangel
Ironangel's Avatar
What do yours measure from center cap to street? Mine measures 13" to center of cap (spindle) and 28" to the edge of the fender opening...
"Two Seventy Two's"
02 3/4 ton Express
Old 04-09-2014, 03:07 PM   #7
ochre70
I've about 13" to the center of the caps also, but about 27 1/2" to the fender... How much would HD springs lift up the front and how much rougher of a ride are we talking?
Old 04-10-2014, 03:02 PM   #8
ochre70
Ttt
Old 04-10-2014, 06:57 PM   #9
Tim Christian
Tim Christian's Avatar
That is no were close to stock height.
Tim Christian is offline   Reply With Quote
Old 04-10-2014, 07:36 PM   #10
ochre70
Its not supposed to be. I've got 2 1/2" drop spindles on it with stock height springs. What I'm trying to figure out is if it looks normal with that setup or if its sitting too low for some reason.
Old 04-10-2014, 09:02 PM   #11
Tim Christian
Ok I read the post wrong
Old 04-11-2014, 01:28 AM   #12
OARNGESI
OARNGESI's Avatar
That looks way too low for just drop spindels
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-11-2014, 06:36 AM   #13
ochre70
No worries, Tim. What could explain why its sitting so low in the front, Oarngesi? Should I have put HD/BB/whatever springs up front instead of standard duty or is something else wrong? Thanks y'all.
