60-66 King Pins
I'd like to rebuild my king pins on my 3/4 ton dana 44. Rockauto.com lists both steel and nylon inserts...which do I have/need/want?
Re: 60-66 King Pins
There is the 44-5f and the 44-5Cfhd, which I believe is the heavy duty. The 5f, that I have in my 62 took the 5/8" cone bearings and cups both top and bottom. I believe the heavy duty version has bushings in the top.
Re: 60-66 King Pins
Ok so if I have a 3/4 ton it should be the heavy duty? Rockauto is unclear - the only difference I see for a 1500 1965 is either nylon or metal bushing.
Re: 60-66 King Pins
So there is Moog 8492B and 8294N - which fits my truck?
Sorry for the weird questions but I want the parts before I tear it apart. |
Re: 60-66 King Pins
You are talking about a 4x4, right? The moog kits look like 2wd kits
My 62k20 has the 5f, not the heavy duty. You have to get the number. Should be on the pumpkin on a tag or cast into the housing. |
Re: 60-66 King Pins
# 3 is the model
1961 chevy K10 my build is------------61K10 build |
Re: 60-66 King Pins
I'm in a similar boat, except I see 2 numbers where the model number is supposed to be,
its a "44 56". I'm getting out the wire brush today and looking for the BOM. shops say its the best way to be 100% sure about what you have exactly |
Re: 60-66 King Pins
Yoder213--1/2ton is 44 5F
Re: 60-66 King Pins
thank you 61k10
#10 | |
![]() Join Date: Jul 2012
Re: 60-66 King Pins
If you have the "standard duty" dana 44 with 8 bolt seal retainer, then the bearings you need for a "king pin" job are: 11520 and 11590. You'll need 4 of each. 4x4 have king pins, but they're a cup/cone style set up with the pins bolting up. Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
| Bookmarks |
